Root [ROM] [OA]2.3.20-No.OC-RFS-[FINAL] FOR LAZY CPU USERBASE [Updated: 09/08/12]
Spz0
Android Expert
OpenAndroid ROM 2.3.20
With NO OVERCLOCK -RFS
This is the OA ROM for the Lazy CPU Userbase.
Please refer to the Original OA ROM Thread for full list of features and extras.
Features:
  • No Overclock
  • RFS Filesystem
  • Same everything else.
Note:
Keep in mind that to REVERT from the EXT4 version back to the RFS version, YOU NEED TO HAVE A COPY OF YOUR ORIGINAL BACKUP AVAILABLE (remember in the original OA instructions how I told you to make a backup before upgrading?? Well, this is why!!)!!
If you are installing FROM A STOCK ROM OR FROM CWM5.0.2.7 THE PRIOR WARNING DOES NOT APPLY TO YOU!
ALL DOWNLOADS REQUIRED LOCATED AT THE BOTTOM OF THE POST.
Installation: FOR CRICKET USERS
  • Download CWM5.0.2.7 (Skip if you already have 5.0.2.7 installed)
  • Download OA2.3
  • Boot to Recovery
  • MAKE A BACKUP
  • Choose zip from SDCard
  • Choose CWM-SuigintouLain.zip (Skip if you already have 5.0.2.7 installed)
  • Go back to Main Menu (Skip if you already have 5.0.2.7 installed)
  • Go to Advanced (Skip if you already have 5.0.2.7 installed)
  • Choose Reboot Recovery (Skip if you already have 5.0.2.7 installed)
  • Remember that stock backup you made before upgrading to the EXT4 version? You did make one, riiight????
  • Choose "backup and Restore" then restore that backup you made.(Skip if you already have 5.0.2.7 installed or are on a stock ROM)
  • Once backup is restored, Goto "data/factory reset"
  • Next goto "mounts and storage" then "format system"
  • Once that is done, go back and Choose Install zip from SDCard
  • Flash OA ROM
  • Reboot (may reboot to recovery again. If so, just reboot again.)
  • Wait
    ***MMS FIX***
  • Once booted, start "ApnBackupAndRestore" (located in app drawer)
  • Choose "Restore APN"
  • Choose the supplied file (OpenVitality-MMS-Fix.xml)
  • Reboot
  • Profit!
Installation: FOR METROPCS USERS
  • Download OA2.3
  • Download OA-MPCS-MMS-Config-FIX.zip
  • Boot to Recovery
  • MAKE A BACKUP
  • Choose Install zip from SDCard
  • Flash OA ROM
  • Once flashed, flash the MPCS-MMS-Config-fix.zip
  • Wait
  • Profit!
**note: if MMS does not work, start up APNBackupRestore (preloaded) and restore the APN OA-MetroPCS-APN-FIX.xml. Reboot.
CWM 5.0.2.7
http://openzio.rtrnetwork.com/openzio/OpenAndroid/utils/CWM-SuigintouLain.zip
OA-2.3.20 ROM
http://www.androidfilehost.com/?fid=23329332407568745
OA-MMS-MPCS-FIX
http://www.androidfilehost.com/?fid=23329332407568806
is OA-MMS-MPCS-FIX for the the lazy admire the same as the one for the overclockable admire. couldnt i flash the other instead of this one?? just wondering
since i actually have a lazy admire when it comes to this your kernel i will be happy to report what comes from this but im sorry that it has to be a two day wait :(
first attempt: alright so i flashed the rom and it didnt go through all they way. yes i flashed it right, i followed the instructions and everything. upon trying to use my phone there are apps within the rom was force closing thus making the phone unusable. it seems that it flashes the rom but all the app within it are on it and i have the notification bar
2nd attemp: its seems that all the apps still force close but this time holo launcher is completely f*****. its always force closing, again making the phone unusable.
correction its not all the apps within the rom fc'ing. holo launcher, swype, music , android.process.acore
Ack!!
I forgot 3 crucial steps!!!!!! hahahaha
Sorry m8.
When ur in CWM, before flashing the ROM, goto "data/factory reset" then once thats done, go into "mounts and storage" and "format system", then flash the ROM.
Sorry about that. Updating OP Post. =\
Ack!!
Sorry m8.
lol its i just kind of assume that since OC rom automatically did that for you that so did this one. no hard feelings mate. i flashed and the it went through now no fc'ing now. its all good under the hood so far. ill report back anything i find. the one thing i know for sure though is that flashing the ics theme by kage does not work for this version xDD but thats outside of this rom
edit: scratch that theme does work, i had forgotten to mount system and data :D
hey, love the rom, finally it works for us Lazy Admire owners :D but i've noticed that i've had a problem connecting to my wifi network, it just stays at obtaining IP address? any fix for that?
Wifi works fine on my donor MPCS Admire. Perhaps your password is wrong?
my wifi also works fine. something ive noticed is that when flashing roms you might get some sort of issue with the wifi but for me is just have to either toggle it off and on again or get close to my router and its good forever.
Spz0: this version is running good, only had one random force closings. one while using the browser but i believe thats a problem with the actual browser app itself cause i had the same problem with the OC version. I saw that you already went and fixed the camera button issue. ill flash the updated rom after i download it. so far everything is buttery. i dont forsee any major issues in the future. Id also like to thank you for the contribution you made to the samsung admire :congrats:
Thanks m8, appreciate the props. :)
As always everyone is always able to contribute themselves by buying me a beer (donating). ;)
:beer:
Cheers!
Hey, I'm trying to install this no overclock rom to my Admire but it appears that the download link to the non overclock rom isn't available any more. Is there any chance that you'd be able to get the link working again? Thanks in advance.
Ack!!
Sorry m8.
SO I am Having Pretty much the same issue here that this guy is having but when I follow your tutelage given, I get following errors in CWM
E:Cant't mount /cahe/recovery/co
"/lo
"/Log
"/La
"/Las
About 6 of these one being system, I Reflashed the 5.0.2.7 And ROM OA but still get same thing....
Also the annoying yellow triangle....
I love this ROM You did great and also I was a dumbA** And didnt back up my Stock Cricket Rom.... So yea... I am unable to find it anywhere....
Any help would be awesome. Thanks in advance
Also Big Props to You Spz0!!!!!!!
Search for crickets eh29 leaked update I posted in these sub forums. Flash that. It will give you a fresh start. You'll have to root and Odin cwm again.
  • Download OA2.3
  • Boot to Recovery
  • MAKE A BACKUP
  • Flash OA ROM
  • Wait
    ***MMS FIX***
  • Reboot
  • Profit!
my recovery menu only has "apply sdcard:update.zip" ... do I need to rename each. zip to do this? ... is it OK, and will I be able to... boot normally, after applying cwm, to rename the OA .zip?
I also have no "backup/restore" or "mounts/storage" option.
my phone is a brand new cricket sch-r720 ... hardware version. 06 ... baseband eh29
I'm presuming I can do the "flashing" via "apply sd .zip"? ... not Odin? ... I downloaded right onto my phone... sdcard/download/ ... do I need to move them?
I also have no desire to be on the cricket network... wi-fi only... if I don't do "mms fix", I'm GTG? ... or will it still try too acquire their network?
thanks!
ok so i download that MMS fix file right? am I supposed to run it or something? I'm kinda new at this. Anyways am I supposed to flash the rom first then go back into the recovery an flash that zip too?
I'm in no better shape than you ... but, FWIW, the way I read his instructions, maybe there's an app called "ApnBackupAndRestore" on your phone, after you're finished installing the new ROM?! ... and if ya run it, there's probly a button 'er menu that says "Restore APN" ... and if ya choose that, it'll prompt for a file on your phone?! ... pick the .xml file ... "profit"?!
Outta curiosity, what did ya find to root your phone ... and any good instructions (pic-heavy) for using Odin to flash the CWM?! ... at least, based on what I've read elsewhere, that's what I need to do, before I can "flash" the ROM?!
I've Odin'd ICS to my tablet ... but that was a very simple deal ... just plug it in, hit the "PDA" button and choose the one file ... click "Go" ... reboot ... done! ... no rooting ... no CWM ... very simple!
Not sure why this new ROM is any different?! ... but, it must be?!
I did root my tablet once ... that was fairly simple, to start ... downloaded a .zip right to the phone ... recovery mode let me browse right to it ... and it was somewhat rooted ... but then when I tried to do the rest, it wanted a couple other apps and permissions and what-not! PITA!
Anyhow, if ya found any good links, please lemme know!
Well everything works fine for me but I found a new error with the wifi. when you first turn on the wifi it works 100% but I noticed if you turn off the wifi an try an turn it back on you get an error. it won't even give you the option to change the wifi settings because there is a error. But anyways I guess I can give that a try idk. But I used odine an im using CWM 7 I didnt have a problem with the google play like the others surprisingly which im happy about an everything else works 100% besides the MMS an wifi
If I dont have a backup anymore and i dont mind the ext4 file system, but my phone really doesnt handle the overclocking at all - can i still flash this to remove oc?
Nice, just installed it on my Admire.
I'm really liking the speed on my phone easy customization also, very simple to use.
