Root [ROM] One rom to rule them all... | Droid Incredible
adrynalyne
Android Expert
Server rollbacks stink.
Alas, Google has some good redundancy :D
Edit Better yet, member mirwolf had the most recent copy!
Without further ado:
One download. Four roms. Pure awesomeness.
Hey folks,
This is a culmination of all my roms, built into one package.
PLEASE READ THE ENTIRE POST BEFORE INSTALLING!
Collection
Second leak based (thanks mrozzeh): Non-sense
Second leak based (thanks mrozzeh): Sense (Default)
Frankenrom based: Sense
Frankenrom based: Non-sense
Pre-reqs
S-off, via unrevoked. http://unrevoked.com/rootwiki/doku.php/public/forever
AT LEAST 500mb free on your sd card. Also, under no circumstance do you want to remove the sw_files directory on it that will be created.
New radio recommended. [RADIO] 2.15.00.07.28 radio
ADB installed on computer required for all features. http://wiki.cyanogenmod.com/index.php?title=Install_the_Latest_Android_SDK
Terminal emulator also recommended once installed. http://www.appbrain.com/app/jackpal.androidterm
Link
http://adrynalyne.us/files/roms/ortrta/one_rom_to_rule_them_all.zip (beta 3)
MD5: 39BDC5AC3FC821A85438B14C4773A68B
http://adrynalyne.us/files/roms/ortrta/precioussssss.zip (beta 4)
MD5: D2C372A4EB72922F52CB911D17A30A5D
Instructions for installation
Download from above link and place on sdcard.
Boot into clockwork recovery, and choose install zip from sdcard.
Navigate to your saved file and install it.
-wipe data/factory reset.
-reboot system now.
Scripts
Can be run from within Android, or via ADB.
sysro -Mounts system as read only and syncs the OS (not data sync)
sysrw- Mounts system as read write
rem_vvm- removes visual voice mail
rem_hot- removes 3G hotspot
rem_ba- removes backup assistant
v_lock- removes HTC lockscreen
rem_foot- removes HTC Footprints
Advanced scripts
These should be run from clockwork recovery via adb. A data wipe is HIGHLY recommended after running any of them. Running them from within Android is a risky ordeal.
BEFORE running these, you need to mount /system and mount /sdcard from the partitions menu (or for newer versions, Mount and unmount partitions menu).
To enter the shell to run these via adb:
Code:
adb shell
cd /system/xbin/
./frank-Installs frankenrom b3.
./vanilla- Removes Sense and enables Vanilla rom based on 2nd leak. This also works for Frankenrom!
Features:
Newer gmail client.
Vanilla features newer stock email client.
hulu ready- check sw_files/hulu_install folder on your sd card. Same for flash installation.
HTC music is default in vanilla due to issues with stock music app not reading internal storage.
More default apps left in, that can be removed via script. This will help those who want back what I removed before.
New default ringtone.
boot animation and sound relocated to /system/media as they should have been all along.
Spare Parts, compiled from source, and ad free.
Busybox 1.18.git (credit stericcson)
32m vm heap.
Latest superuser 2.3 by ChainsDD.
Basic file manager for accessing sd card immediately after installation.
Market install fix (I hope). Beta 4
Scripts can be run at startup in folder /system/etc/init.d. Beta 4
Bash shell included. Beta 4
Helpful Hints
Use ROM Manager to fix permissions when switching roms. Very important.
Understand switching a rom is a one way street.
Second wave can go to vanilla.
Vanilla can go to frank.
Frank can go to vanilla.
Vanilla cannot go to second wave.
Frank cannot go to second wave.
Frank does not contain maps. After using rom manager to fix permissions, download it from the market.
After install of any rom, reboot once more. The GPS gets stupid if you don't.
First boot when switching roms, or first install is very slow. Patience, grasshopper!
Make nandroid backups, and do it often. It sucks to reinstall a rom this big when you make a mistake you want to revert!
Performance
Performance is what you should expect from my ROMs.
Hydra kernels seem to work fine per Asterdroid.
Asterdroid was seeing some very impressive numbers under Frankenrom with the 1.15 ov kernel.
Optional
Streaming audio fix (breaks Hulu audio performance)
http://adrynalyne.stfuthxbye.net/test_patches/stagefright.zip
Asterdroid for help with beta test 1.
Everyone else for help with beta test 3!
Important Links
http://adrynalyne.us/ --For up to date information.
http://adrynalyne.us/forum --For links and if need be, support.
http://adrynalyne.us/chat/ --Live chat. I do not guarantee I will always be there, but its for everyone.
The reason I'm getting lower Qudrant scores as I used to is I didn't install Streaming audio fix right?
Can't wait to try this out. Surprised that the 50 or so posts on this are gone :(
Awesome Instructions for the somewhat new to ADB.
Thanks for all your hard work and time put into these ROM's!
*chuckle*
Go into set cpu and set your governor to performance.
Dont leave it that way too long, if you like battery life.
Yeah, but you dont need to change the bottom slider. Max the top slider, and then choose performance for the governor. By default its ondemand.
If I install frankenrom b3 via adb would I do data wipe before I run the adb command to install our after its already installed?
is there any advantage to this over the second wave? I have it set and really dont have any problem... if I flash this I will just leave it at the default... I haven't flashed in 2 weeks *twitch*
I can't fix permissions after flashing franken rom b4. It says an error occurred while attempting to run privileged commands
