Root ROM Performance & Battery Life
ModifHigher
can i get some input from folks on their setups,like cpu clock speeds and governers,a2sd or not etc?
im trying to use other opinions to decide what will get me the best performance and battery life,im willing to trade performance for better battery life.also,note if youre using an aftermarket or extended battery.
if you can,just tell me a few things
A.what ROM youre running
b.your best settings that made your battery last longest.
c.CPU Clock Speeds/Governers And I/O Settings.
i just realized i dont even have an official samsung battery,its a 1600 MaH chinese make of some sort.
thanks to all in advance.
and also,im anyone has pointers on what i can do to extend my battery life let me know.
Turn off GPS, wi-fi, sync, Bluetooth as much as possible; there is a great stock widget for easy access. Watch for apps that update too often (email), kill background apps, low signals, aftermarket batteries - all drain batteries. You can easily get 1-3 days from a battery charge if you
The stock (Android) task manager was removed by Bloodawn but can be reinstalled, he gives directions in his thread.
Watch settings>applications>manage applications>running to see if you can cut anything. (examples: I cut DRM content and Google maps) Also FREEZE apps as possible (Facebook always restarts itself when cut)
I keep task manager and manage apps as icons on my qwik bar in a folder and I check them almost every time I sleep my phone.
I run CTNaked Glass as my description on left shows.
Your aftermarket battery being a 1600 when stock is 1500, you might not get much less life, I really can't say.
