StaticMaal
I bring to you Motorola Triumph user MokeeOS. From Huawei Idoes X6!
Working:
- Data (3g)
- Text
- GPS
- Cameras (You have to use third-party app)
- Audio
- Wired Headset
- Hardware Acceleration
- USB Tethering
- Basically Everyting that works on CM7 expect WiFi and Portable Wi-Fi Hotspot
Features:
- based on CyanogenMod 7.2.0 RC1
- Themes support
- Completly NEW UI
- 3 Tabs on status bar notification
- Swipe Notification
- Deodexed
- Zipaligned
- English + Chinese language only
- ADW Launcher default
- Camera with scanner code
- Smooth
- Stable
Bugs:
1. Wifi doesnt work
2. After applying a theme then pressing menu button in ADW Launcher no menu appears
3. FC if you access Superuser from Settings>System>Superuser (try to open the app itself which i added)
4. FC if you long press on Flash Light in Tab notification se (It works)
5. FC if you try to access Settings>System>CPU OverClock (please use for now other app for overclocking if this rom is not fast and smooth enough)
6. Dont try to change the language from Settings>Personal>Language&Keyboard>Select Language> you gonna see only chinese language if you press those 2 chinese characters from this settings and you have to flash the rom again, for some reason english is not present
7. dont know right now if these are bugs but i'm gonna try to fix it.
8. After the first boot let the system spend about 1 minute to became stable
9. Wi-Fi Hotspot is not working.
10. Anytime you press the menu button the app force closes. (Only if you have GingerBlurBattery Theme Enable
11. Front Facing Camera dont work.
12. No HDMI.
13. Everything that dosen't work and CM7.
Download:
MokeeOS_MT-v0.3.120318.zip
Working:
- Data (3g)
- Text
- GPS
- Audio
- Wired Headset
- USB Tethering
Features:
- Themes support
- Completly NEW UI
- Deodexed
- Zipaligned
- Smooth
- Stable
Bugs:
1. Wifi doesnt work
12. No HDMI.
Download:
I'm ready to try it once wifi is working
