Root {ROM}{PORT}GingerDx(PIE CONTROL)
hello admire community. an admire was "donated" to me recently and i decided to return the flavor. i present gingerdx, a rom i originally ported to the huawei ascend2. built from playfulgod's cm7 source. the features of this rom are amazing and far surpass standard cm features. lets begin with them.
original base op:http://androidforums.com/admire-all...ta-cwm-cache-issue-addressed.html#post5243063
original port op:{ROM}{PORT}GINGERDX-PIE CONTROL
FEATURES
all cyanagenmod features from Requisite0's cm7 (apparently we compiled from same source (ie playfulgod))
gingerdx features: pie control, jb-status bar,notifications, etc/ call features-call me louder, loop ringtone, custom carrier label, etc./alarm- math quiz, flip/shake actions, increasing volume, etc./led- options to disabel led at the night./other- ultra brightness, lockscreens, center clock, etc.
*theme: featuring achep@xda's wonderful jb theme.
*******YER WARRANTY IS NOW VOID, RESEARCH BEFORE MODIFYING YER DEVICE, I AM NOT TO BE HELD RESPONSIBLE FOR YER ACTIONS.*******
INSTALLATION
YER DEVICE MUST BE ROOTED
google vroot or yer source choice
YER DEVICE MUST HAVE THIS RECOVERY INSTALLED
Dev-Host - CWM-6.0.3.2-rookie.zip - The Ultimate Free File Hosting / File Sharing Service
DOWNLOAD THE ROM
https://drive.google.com/file/d/0B5FXgIkne2uXTlR1ck9Ya2Zqc1E/view?usp=sharing
DOWNLOAD GAPPS
GOOGLE
1. PLACE ROM ON SDCARD
2. BOOT RECOVERY (HOLD VOL. DOWN, BACK KEY, POWER WHILE DEVICE OFF.)
3. PERFORM ALL WIPES. FACTORY RESET, CLEAR CACHE, CLEAR DALVIK CACHE.
4. FORMAT SYSTEM-MANDATORY
5. INSTALL FROM SDCARD, SELECT 1cm-dxadmire.zip
6. INSTALL GAPPS
7. REBOOT
POST INSTALLATION
UPDATE THE FOLLOWING APPS: SUPERSU AND QUICKPIC. otherwise, no root or gallery.
INSTALL THE FOLLOWING APPS: SUPERUSER AND CAMERA ILLUSION. download either via playstore or yer source choice. to allow root and camera. otherwise, no root or camera.
BUGS
NO BUGS BESIDES MENTIONED CAMERA BUG
SOMEONE SHOULD VERIFY IF DATA WORKS
THANKS
ALL THANKS TO THE DONATEE OF THE DEVICE, CYANOGENMOD, TEAM FUN, PLAYFULGOD,
REQUISITE0/Spz0,ANDROID, AND GOOGLE FOR BEING OUR FRIEND.
SCREENIEZ
Wow, never expected any new developments on this old phone - thanks!
I followed your steps & installed the ROM but SuperSU can't update its binary. I've tried the normal method and recovery. Any ideas?
POST INSTALLATION
try it^
Okay, I installed Superuser first and then was able to update the SuperSU binary by the recovery method. After that I opened SuperSU and got a message asking to delete Superuser to avoid conflicts. I did this and everything seems to be working.
Off to try the swap next :)
So dope to see new shnit on the indestructo smart phone otherwise known as the admire. Still use mine as a wireless controller for my entertainment pc and a music player while I'm around the yard. Don't have any data service so I cannot give any feedback as to whether it works or not. I'll let you know If I come across anything else though. Again, thanks for the new toys.
Similar to me. Mostly use mine to play music or look things up while working in my garage, avoids getting my current phone all greasy.
i ported an android l mod also. team nexus is overlooking my permission to host. im sure they are busy with new code.if anyone knows roomz or duca @xda from team nexus, maybe drop them a line so i can share this.
Not sure, didn't use the admire much, as I picked up a gnex shortly after and w/o data. I use easy battery saver from the play store. This ROM on my ascend 2 with the battery app would run for 3 days on a full charge. However the ascend 2 also has smartass2 governor kernel. Both the ascend 2 and the admire running the newest ROM I ported with the battery app, ran 3 days on full charge. Considering little to no use. I'm not sure what cm7 before my port ran on the device, considering cm7 on the ascend 2 running the app I mentioned, better battery life for gingerdx
Okay. When I have a chance I will install this ROM and check how data works... Also, no overclocked kernel? :0
EDIT: okay so if you built this off the CM7 spz0 released then it does NOT have data working unless you somehow worked on it to fix that issue. I read the whole 6 pages in the thread trying to see if anybody found a fix too but found nothing :/
