youonlyportonce
PLEASE IGNORE THE POLL, THE TOUCHWIZ LAUNCHER IS WORKING. WE FOUND A FIX AND IS ALREADY IMPLEMENTED.
I think i may have a breakthrough for the people wanting Touchwiz on the OE, i just ported a modded custom ROM for the LG L7 (its bassicaly an GS4 based ROM)
What works:
What doesn't work:
Flash at your own risk, i am not responsible for any damage to your phone, so be sure to make a nandroid backup.
To flash,
Factory reset (only needed if coming from something other than CM9)
Clear the cache
Clear the dalvic cache
Install ROM from zip
Boot up phone
Important:
After flashing rom and gapps make sure that the phone is NOT plugged into a computer when you first boot up. This for whatever reason eliminates touchwiz crashes.
Sprint-
Touchwiz OE Sprint Final
Virgin Mobile-
Touchwiz OE Virgin Mobile Final
Gapps
CM10 Gapps
Extras-
Flashable Yahoo Zip
Flashable Media Zip
____________________________________________________________________________________________
TouchWiz lock screen from play store
To use, simply disable the original lock screen by going into lock screen, tapping where you would choose what type of lock you want, then hit disable. After all that, just enable the app in app drawer and enjoy
Be sure to comment on your findings so i can get them fixed ASAP
Base ROM thread link-[ROM] LG L7cm10 galaxy S4 / update to CM10.1 galaxy S4 beta 2 - xda-developers
Also thanks to phenomx4 for his CM10 ROM, kenharkey7, szyme10 for the l7 ROM, and all of you for any help you give
Thanks guys
What works:
- Everything in CM10
What doesn't work:
- Anything not working in CM10
- Fixed Torch
- Fixed Roaming Indicator off
- Removed boot to boot loader option
- Fixed 3g in status bar
- Removed Weather widget (You can just get in the play store)
- Removed Yahoo stock and news widgets (flashable zip available)
- Removed a lot of ringtones and other sounds (flashable zip available)
- Replaced clock with one from cm10
.Flash at your own risk, i am not responsible for any damage to your phone, so be sure to make a nandroid backup.
To flash,
Clear the cache
Boot up phone
Important:
Sprint-
Virgin Mobile-
Gapps
CM10 Gapps
Extras-
Flashable Yahoo Zip
Flashable Media Zip
Thanks guys
