LowEndGeek
Android Expert
This came about cause I just decided to take a break from Paranoid Android and looked to see what else I could port.
This is slim bean 3.1.0 based on jelly bean 4.1.2 and ported from the Optimus L7 using phenom's cm10 rom and includes the latest camera patch.
# What Works:Thanks to:
- Phenom for CM10 for the Elite
- tudorsirb for the slim rom for the L7
- The slim team
- The cm team
- and last but certainly not least, all of you
Everything that works in cm10
# What Doesn't Work:
Slimbean ota (will likely never work, will try to remove the option in the future)
Whatever else that doesn't work in cm10
Start up tweaks do not work because i have not included the required scripts for them. They broke the rom in testing.
# Minor Annoyances:
Shows 1x instead of 3g but still has 3g connectivity
Install instructions:
If you are coming from a previous version of slimbean you do not have to do a full wipe, just wipe cache and dalvik cache and flash the new rom, if you are coming from any other rom a full wipe is recommended.
- wipe data/factory reset
- flash rom
- flash slim-gapps
- reboot
- wait
- Enjoy
## To avoid any potential issues it is HIGHLY recommended you flash the provided slim gapps, however if you are having issues with the play store updating then flashing the normal gapps is just fine.Changelog:
1-16-14 Initial release
1-17-14 Fixed storage to allow both emmc and sdcard to mount, removed boot to bootloader option
1-21-14 Small maintenance work, fixed torch and small graphical issues
Downloads are here
Here is the default slimbean wallpaper
