Root rom probs HELP..
shewbie2
HEY Sorry if there is already a thread on this i didnt see one. So i have a fully rooted evo hardware 0004 hboot .97...... every rom i flash has lines in the screen and flickers. I was told it was the kernels making the problems idk. But when i flash back to stock evo rom its 100% ok.....
if u know or have any ideas what i can do to use custom roms plz help..
I would lobe to help but we need some more info... what roms have you flashed with this problem? When the problem occurs are you using an HTC kernel or custom kernel?
You're having a "Screen Tearing" problem. Happens with some devices.
My recommendation is this.
Flash Calkulin's newest rom, [ ROM ][ 11-23 ] Calkulin's EViO 2 ROM v1.6.2 [ FroYo l FRG83 l OC l UV l Themeable ] - xda-developers
Start with the first, stock kernel. If that fails, try flashing kernels, until you've tried at least 6-7. (Helpful if you use diff varieties, don't use 7 versions of Toast's CFS, use many different ones, w/ and w/o HAVS, BFS and CFS) Good luck.
Netarchy makes great kernels: [GPL][Kernel]netarchy-toastmod, Stable: 4.1.9.1 Beta: 4.2.1 - xda-developers
FULL ROM LIST: HTC Supersonic/ROMs - XDA-Developers
BTW, what roms have you tried?
cm6,miui,myn2.2, and just the kernel that is with each rom, stock rom and kernel works just fine. thanks for any help sorry for like of info.
alternative HTC Kernel: [KERNEL] v2.6.32.17-gee557fd htc-kernel@and18-2 #15 - xda-developers
New Sense based kernel: [KERNEL][WIP][SENSE] - Superior Battery Charging - xda-developers
Zendroid Kernel: [KERNEL][AOSP][2.6.35.9] ZenDroid 0.91-BETA (BFS+CFS) - xda-developers
And another: [KERNEL] Undervolt driver for the stock HTC kernel for EVO 4G and others (2.6.32.15) - xda-developers
These are just a couple, check out the Evo development thread on XDA, read, read, read. BTW, you said above you've only tried the kernels with the roms. You need to try applying some alternative kernels after the rom you choose, see if it changes anything.
Additionally, after installing the rom, another recovery boot, wiping cache and dalvik cache wouldn't hurt either.
do i flash the rom then flash the alt kernel what are the steps to flashing kernels i have not done one yet. ps thanks alot for your help.
Flash Rom
Boot
Boot into Recovery
Wipe cache x3
Wipe Dalvik cache x 3
Flash Kernel
Boot.
PS, theres a thanks button if you're truly thankful ------>
