Root Rom Question? ???
Choose any ROM you want, with everything working, so nothing based off CM7 because it's still a BETA.
Look around the thread, and I'll help you with Tweaks and Mods.
Also to fix the Thread Title, go to the first post, click edit, then click advanced AND TADAAA you can edit the title.
Just CPU Changer isn't going to make a ROM fast.
Go to the ROM Gathering Thread, and choose a ROM//
& I bumped it just for you.
Thanks but i read a post and it said some roms are faster than others like on the post it a said like stock++ was the fastest and somewhere it said CM7 was faster so WHICH 1s FASTEST is all im asking
every rom can be fast..it simply depends on the tweaks and mods you add with it and how clean your available memory is along with the overclocking/undervolting you do.
find a rom to your likes and tweak the hell outta it...do speedchecks inbetween tweaks and see what makes the best difference..all phones handle it differently.
Thanks Aboat, & SA
But he's clearly new at this, and I don't want him to flash a BETA ROM and then complain that nothings working -.-
