does it support app2sd.
on other note why the h*** do all of you just copy and past the features. this is the 5th rom that i have looked at and all have the same features list... in the same font... in the same color...![]()
Firstly you can always set up a build environment, apktool, java and build something to your liking...secondly they're all AOSP based 4.4 so they all WILL look the same. Each ROM has different features, for interface, performance etc. The 5 Roms are COMPLETELY individual so you obviously know nothing about the various teams, AOSP, AOSPA, CM, Slim, AOKP etc...again feel free to build something...if you think you can do better than the above mentioned teams.![]()
I don't have time to do each thread differently.does it support app2sd.
Starkraving snapped lolFirstly you can always set up a build environment, apktool, java and build something to your liking...secondly they're all AOSP based 4.4 so they all WILL look the same. Each ROM has different features, for interface, performance etc. The 5 Roms are COMPLETELY individual so you obviously know nothing about the various teams, AOSP, AOSPA, CM, Slim, AOKP etc...again feel free to build something...if you think you can do better than the above mentioned teams.![]()
Video works on my ROMJust installed. Feels pretty snappy.
Video still not working in Hangouts.
I don't use video chatI use and need both, depending on which family member or friend I'm talking to. Besides, I'm trying to help by reporting a potential bug. Your remark proposes a work around but doesn't fix the bug.
