Heliotropic
Member
Has anyone been able to download a complete copy of this from GrdLocks site yet? I've tried 5 times and none will pass md5. Is it a hosting issue or is it me?
everytime i try to install the rom it says
"install from sdcard
finding update package
opening update package
E: cant open/sdcard/sense-able.2.0.zip
(bad)
installation aborted."
same with 0.7 version
why is this happening
any help![]()
Looks like you're having the same problem I'm having. Check your md5. You'll probably find the file is incomplete.
I love the look of the dialer now...i did notice that some of my icons changed back to the original 2.1 icons such as the camera and settings...was that supposed to happen?
Dont know if its the ROM or the dialerone that I added but I no longer get different rings tones for certain users. Like I have diff ones for certain users. I have it set, but it always goes to the default ringer. Anyone else have this issue or is it something else? I posted in the dialer thread as well just to see where the problem might lay. I have no problem reflashing and adding app by app but just wanted to see first if anyone else having this. Thanks in advance guys and still love love this ROM
Hey guys, I'm new to this, but I really like the look of this ROM over the stock Sense. My question is... Is this built on top of Sense, or is this an Android ROM that is made to function similarly to Sense? I'm just wondering if it will have 7 or 3 screens, and if the HTC Widgets will still work.
Thanks and great work!
its themed sense
all the htc widgets work and its 7 screens![]()
Yes this is 2.1...But just to make sure..You are rooted right? Otherwise this won't for ya.Haha awesome, I was actually just gonna come back into this thread and re-ask the question that way... I thought it might just be Sense but with different graphics. Sounds like that's exactly what it is, and that's exactly what I wanted
And if I read the OP correctly, this is also running Android 2.1? If so, I just might be a little too excited for words, lol...
haha... But I know once I learn how to do this, it will become as addicting as crack... Happens every time I learn how to customize something
These directions are a bit clearer How To Root Your HTC Eris and go step by step. If you have any problems or questions go to the IRCI am still on 1.5 stock, haven't done anything yet. I was just going to wait for the OTA, but after seeing your screenshots, I'm quite interested
So I am guessing I would have to install the 2.1 rooted ROM (http://androidforums.com/all-things-root-eris/53963-guide-stock-1-5-latest-root-2-1-a.html) first, and then this one?
I found the instructions for rooting, but I can't seem to figure out Step 3 here (install zip). Would I just install it the same way? And would it need to be renamed first?
Sorry, I hate being such a noobhaha... But I know once I learn how to do this, it will become as addicting as crack... Happens every time I learn how to customize something
no that was my error, while changing stuff around. I didnt notice till after i already uploaded. they will be fixed in the next release
irc.thefuzz4.net:6667
#ErisRootHelp
And I'm sure someone will help you out.
A lot of people including myself sometimes just hang out answering questions, because we have nothing better to do.
And no worries most of use are addicted to the ERIS...there is quite a bit you can do and customize when you root.
Awesome, thanks for that... looks pretty straightforward except for one part:
IV: Flashing a custom ROM
1. Download the custom rom of your choice from here.
2. Copy the WHOLE zip file to the root directory of your SD card. (You can enable USB-MS enable from your shiny new recovery to mount your phone as a USB Mass Storage device.)
3. Choose Wipe. Choose data/factory Reset (In the stock ROM, the dalvik is stored in the data and you don't have an EXT partition... yet.)
What do I do between steps 2 and 3?? After copying the new zip into the card, what do I do to get to Step 3?
Thanks so much for the help![]()
How did you remove the dialer? Or did you do a restore from NAND?
I did a NAND restore....thats one thing i've learned...I alwasy do a backup before I make any changes...
