Root [ROM] SphinX G3 Neo V2.0 for D855 16/32GB, D855TR, F400 L/S/K
hoangnova
SphinX G3 Neo V2.0
Based on V10B D855 Stock (latest)
V2.0 Final
  • Removed all warez
  • Fixed Video recording sound
  • Fixed AUX output
  • Fixed bluetooth connect problem
  • Removed BMW, Audi bluetooth backlist
  • Added LG Software PC Connection
  • Added TahitiBlue, TahitiPink, TahitiWhite theme (thanks [MENTION=270378]Cloudyfa[/MENTION])
  • Supported all apps Splitwindow
V2.0
  • Supported D855
  • Latest GApps
  • Supported Aroma install
  • Removed loading Usim contact toast message
  • Removed SuggestedThemes and PlusImage in ThemeChooser
  • Added QMemoPlus Widget
  • Added PC connection in Setting Menu
  • Added Auto call record
  • Added Vibrate when hangup the call.
  • Added 2G/3G Quicksetting button
  • Added LGVideos, LGHealths, LGBackup shortcut
  • Added all weather effects: Clear and Cloudy weather effect
  • Added Mms view mode: Tab or conversation view
  • Added new feature: Turn on (or not) screen when message is received
  • Added SMS signature
  • Added SMS counter
  • Upgraded 10E Kernel & Modules (F400L/S/K)
  • ZipAlign
  • Odexed
  • Busybox
  • ..... and more
Step 1: Preparation
  • Backup your data, sdcard.
  • No require root
  • Download rar file and extract
  • Install driver (skip if installed)
  • Enable usb debugging (tap 7 times to About phone/Software information/Build number, go back to Settings/ Developerment options/ check Usb debugging)
  • Connect to computer with Send images (PTP) Mode
Step 2: Flash ROM
  • Run FlashROM.bat, press any key first time, and reboot recovery
  • From Recovery 3e, choose "wipe data/factory reset", then "wipe cache partition".
  • Then, choose "apply update from ADB", wait a moment for your computer install adb sideload driver.
  • Press any key 2nd time from your FlashROM command window.
  • Wait some minutes
  • Choose your variant in Aroma
  • Reboot system now and Enjoy
In short :
- Download and extract
- Install driver, enable usb debug
- Run FlashROM, wipe, choose "apply update from ADB" then press anykey to flash rom.
- Choose your variant
Bugs / Reqs
1. ART not works ?
2. LGQRemote ?!
3. Bluetooth transfer file problem ?!
4.
Flashed this yesterday on my F400S.
Everything is working fine except for audio streaming (APT-X) over Bluetooth.
I am using a SONY MDR-1RBTMK2 Bluetooth stereo headphone.
I am getting audio however the pitch and speed is not correct.
I have used the pitch and speed option in Eq however they are only able to compensate 75-80%.
Addon
Download and install.
LGQRemote App:
LGQRemote.apk
Donate
If you like my work, click here to buy me a beer.
Credits
Thanks [MENTION=1167021]Hendrickson[/MENTION] for Camera mod V2
Thanks [MENTION=270378]Cloudyfa[/MENTION] For his help, support and for his Aroma script.
Version Information
Status: Stable
Last Updated 2014-07-06
