cool.gautam
FEATURES--
JUST 73 MB ROM
Some cool apps
Ziplaign at boot
Some add-ons
App2sd Removed
Bash
Nano
Adw launcher
Dalvik to sd
Vm 38
Removed Bloatware
Tweaks
Jit enabled
A new app for faster downloads ( i bet u'll love it )
Corrected music bug
Megascript by Varun
Working flash with stock browser
Framework customizations ( newer by me )
Build.prop by Varun
Ad-free rom thanks to Varun for hosts file
Removed scripts that caused lag
Corrected USB debugging bug
CREDITS--
Varun for buildprop tweaks , hosts file and megascript , Mastermind for correcting USB debugging error
[ROM]
1) Go back to stock ( imp )
2) reboot to recovery
3) Wipe cache ( not imp. do only if ROM doesn't start up )
3) wipe dalvik cache
4) select install zip from sdcard and select the rom
5) reboot
Newer
Link = Download Hybrid+v3(updated)+by+cool+gautam.zip from Sendspace.com - send big files the easy way
[FLASH PLAYER]
link = Multiupload.com - upload your files to multiple file hosting sites!
Download adobe flash player ans install simple....you can check by visiting whatismyflashplayerversion.com from stock browser
[ COOL CUSTOMIZATION ] OPTIONAL SOme WANTED WHITE some BLACK HERE's COMBO OF BOTH Notification bAR
Steps-
1) Reboot to recovery after first boot of rom
2) wipe dalvik cache
3) flash the zip
4) Reboot
Screenshots---
FOR BETTER RESULTS START SYSTEM TUNER , GO TO TWEAKS , BOOT SETTINGS UNDER CPU , ENABLEE JUST SD TWEAK( AS OTHERS ARE ALREADY IN MEGASCRIPT) ON BOOT AND REBOOT UR DEVICE.
DON'T FORGET THANKS...
JUST 73 MB ROM
Some cool apps
Ziplaign at boot
Some add-ons
App2sd Removed
Bash
Nano
Adw launcher
Dalvik to sd
Vm 38
Removed Bloatware
Tweaks
Jit enabled
Corrected music bug
Megascript by Varun
Build.prop by Varun
CREDITS--
[ROM]
5) reboot
Newer
[FLASH PLAYER]
Steps-
3) flash the zip
4) Reboot
Screenshots---
