DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur. This ROM is UNTESTED since I do not own this device. Use at your own risk.
For Boost Mobile ZTE Force 4G LTE only.
This is completely unmodified Stock B09 ICS 4.0.4 with stock recovery. It will bring your device back to complete stock.
hayes_stock_B09_with_recovery.zip UNTESTED
This is completely unmodified Stock B09 ICS 4.0.4 with root. No recovery included in this ROM.
hayes_stock_B09_root.zip UNTESTED
NOTE: This zip is unsigned so you will need to disable signature verification in cwm before flashing.
NOTE2: Your device must have CWM to flash ROMs.
Flash this in CWM as follows:
Thanks to:
Golono - Uploaded cwm backup
sonicbluemustang - Uploaded stock recovery.img
- Download ROM
- Put the ROM.zip on your sdcard if not already
- Reboot to CWM Recovery
- MAKE A BACKUP!!!!!!!!!!
- Wipe data/Factoy reset
- Install ROM.zip from sdcard
- Reboot
- Enjoy!
Thanks to:
