Root [ROM] Stock B13 Unmodified
SuperR
Android Expert
Recognized Developer
DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur ;)
For Boost Mobile ZTE Warp Sequent only.
This is completely unmodified Stock B13 JB 4.1.2.
NOTE: CWM will be replaced with stock recovery if you don't say "yes" to disable when it tells you it might replace your recovery.
NOTE2: Your device must have CWM to flash ROMs. If it doesn't, please check out Warp2 CWM & Root Flasher
Flash this in CWM as follows:
  1. Download warp2_stock_b13_unmodified.zip
  2. Put the file on your sdcard if not already
  3. Reboot to CWM Recovery
  4. MAKE A BACKUP!!!!!!!!!!
  5. Wipe data/Factoy reset
  6. Install warp2_stock_b13_unmodified.zip from sdcard
  7. Reboot
  8. Go to Android Settings >> System updates >> Update Profile (otherwise MMS might not work)
  9. Enjoy!
Other Downloads:
Stock B13 Recovery
