Root [ROM] Stock+ Beta
boneface
===========WARNING!!!=============​
Please, FLASH AT YOUR OWN RISK!
I am not responsible for your device being bricked, corrupted, melted, or exploding. Thats all on you at this point.
I basically just made this because i wanted to start editing the framework, system ui and kernel.
ok..so here it is..Stock+ Beta.
Q. Why is it beta and how is it different from my stock76?
A. Well, its Beta because im still in the process of adding more features and options, as well as themeing it, so there will be some updates in the future. Updates that i want to get the community to be suggestive about.
Its also Different because this includes full init.d support in the rom and the ramdisk, has really only a few stock apps, no bloatware and it is finally zipaligned and optimized more properly than stock 76.
And im trying to incorporate the best of Google services
Plus, these are getting easier to make so .
Features
deodexed
debloated
Zipaligned/optimized apps (start theming!)
Root/Su
100% init.d support
unsecured boot.img
Busybox
data/app functionality
adobe flash
Miui ringtones/notification sounds
Apex Launcher
Apollo (cm.9 version)
Dsp manager
Root browser by jrummy
Holo Locker
Google Keyboard 4.2
Googlecamera 4.2
google gallery
Sdcard as default storage
Ad Blocker
Link Stock+
Mirror
Instructions
1. make a backup to your external sdcard
2. Download rom, place it on your external sdcard
3. boot into CWM recovery
4. wipe data/cache
5. flash rom from ext sdcard
6. reboot system, set up your google account
7. Reboot rom once more (not necessary now, but when i add init.d scripts in next version, it will be necessary)
8. enjoy.[/B]
*if apollo fc on you, uninstall and reinstall version from the link below
apollo.apk
*Bootanimation is a little small for our screen..my bad threw the wrong one in there at the last minute. will update in next version. till then you know how to add your own, right?
since its deodexed, rom will take a few minutes to load. Be patient.
If it boots up, powers down, and reboots..thats fine. Means its working.
Thanks to:
Shabbypenguin for his build of cwm for us.
ldrifta for getting me into the kitchen
Playfulgod for his pure guruness
google for its ownage.
Please, report any bugs, feedback and suggestions, especially for bootanimations and such lol
Screenshots​
You should add crt off animation and make system backgrounds black :) i would do it but i keep getting errors everytime i recompile
Haha yeah i was tryna do it ever since i got this phone and rooted it but i always get and error when recompiling lol thats why i gave up on the motion and avid i never got an error but idk whats up with this phone haha
Hopefully u have better luck aha
can anyone put this up somewhere else? I've been trying to download it all night, on multiple computers and my phone and it keeps failing, or I end up with a 90mb or 160mb file..which Im pretty sure is incorrect.
alot of the apk dissasmblers dont work on ics for some reason. some of the apks will decompile and recompile fine..still trying.
dev host is pretty lame sometimes. if youre downloading it straight to your phone, make sure its going to your external sd card. also make sure you have a decent network connection that doesnt time out. restarting your router and/or modem usually is good.
at any rate, im reuploading to a different host right now..will put up a link in about an hour
Awesome thanks! I only tried downloading it straight to my phone to make sure the issue wasnt my computer, but Ive got full strength wifi over 25mb connection and pretty much only have that problem with dev host.
Just picked up this phone today and Im still figuring it out, I had just gotten pretty confident with modding my Motion when I lost it and got this instead.
Anyway, looking forward to checking out this rom!
here you go.
updated op as well.
Stock+ - Download - 4shared
Thanx really like...runs smooth...when we gonna get a custom kernel,BTW any way to get a recovery that don't jump side to side...no offence to SP...I thank him for his hard work.
You can build a custom recovery... but it's gonna jump.
At a dev level this phone is all sorts of tarded. Others have tried Modding the recovery to stop the jump to no avail. It seems like if you want cwm to work it needs to be allowed to be just a bit tweaky
