[ROM] [Stock] C811 M070 firmware ZIP file (4.1.2)
ad_rai
22
13
Hello, I am posting C811 M070 for GzOne Commando 4G LTE. These files could be flashed using CWM-based recovery.
The update.zip contains modem, boot, rpm, system, tz, and other parts of images (ex. recovery, sbl1-3, userdata) were omitted. If you need those files, PM me for them.
Warning: This version removes su binary/SuperSU for each boot. Tried to install SuperSU from recovery, reboot, then su binary is gone. Renaming the binary will work.
Download at here: http://main.develoid.com:81/casio/GzOne/stock/Verizon_wireless/VZWM070-update.zip link dead, replaced with newer one
Update: new link here: https://mega.nz/#!8NVV1bhB!_VvDbq4TaMG7YOlyKncKzOF53RtM-szty18vNvr0lJg
Update (2022-03-07): I saw someone requesting the access of my folder on Google Drive. This is probably due to Google Drive's link policy changes, so here is the new link and please don't ask me for permission: https://drive.google.com/drive/fold...ourcekey=0-7YlvS07g8rTYKK73N74J9A&usp=sharing
Also these are directly pulled from what was provided by Casio, so decrypt using this: https://gist.github.com/peremen/71330cbb4a6556358b938e0e353255a6
Enjoy!
Can you elaborate on renaming the SU app? I used root explorer to rename it but that didn't seem to work..
I installed SuperSU update zip inside recovery. Before rebooting to Android, I renamed /system/xbin/su binary to something other (e.g. /system/xbin/surprise) "inside recovery". That preserves the binary accross rebooting.
This makes SuperSU app on Android not working; a workaround is modifying the app's ID to something other than SuperSU, and change every references of /system/xbin/su to /system/xbin/surprise (changed name of su binary).
Upvote 0
So if I'm correct, it is possible to create an app that will receive BOOT_COMPLETED broadcast and use surprise binary to create a surprise symlink to /system/xbin/su at boot. But the problem is that that app must be started before other apps that use root otherwise they will fail to do their maintenance at boot.
I can try making that when I get my hands on some free time.
Edit:
It failed. Not only the su binary is deleted on boot but surprise and any apk I put in /system/app in recovery.
Upvote 0
Dear ad_rai
Following C811M070 Verizon update information:
Android 4.1.2
Baseband Version: M8960A-1.5.38_C811M070
Kernel: 3.4.0
Build: C811M070
Hardware: 1.1
But my Casio fone (CA201L - Korea version) after flash your VZWM070-update.zip file still got Hardware 0.3
Is your file lack some system parts?
I actually do have CA201L, and hardware revision will not change flashing whatever, as far as I know.
  • Like
Reactions: zippo_vn
Upvote 0
Hi to all, I have CA201L korean version after update to C811M070 with CWM my phone lose network at all .The only way to use my phone is with stock Rom without SMS sending . .I use it in Bulgaria GSM operator.It was the same with M040 and M050 can you help pls?
P.S Doctoror I didn't root the phone do you thing this is the reason ?
Upvote 0
I'm sure it has nothing to do with root. But I can't tell what is the real reason behind it.
Try moving to Korean 470 baseband (link). It may break your camera, but may solve the signal issue.
Upvote 0
Hi , I've install M070 again becouse I need the camera too and it works 12 hours till now , if the phone lose net again I will downgrade the baseband.Thanks Doctoror for the attention.
After 24 h loose cover ,but on the displey shows there is normal signal,so I tried to downgrade baseband to 470 in CWM but it was bootloob ,so I installed modmist.zip and after that I installed baseband 470 and IT WORKS!!!!!AND CAMERA TOO.Thanks Doctoror for everything your really helpful I hope this time the baseband will not crash .
  • Like
Reactions: Doctoror
Upvote 0
Glad you've figured it out, thanks for the info!
Upvote 0
hi all, i've use this rom on my Ca201L then my network just can lock 2G network..
i'm using M050 before and it can lock 3G network, i try to flashing back M050 with M050 baseband but it still can't "read" the 3G network just 2G
now i use M070 rom with M050 baseband but still same problem, just EDGE i have :(
oh i live in Indonesia, my phone is root, i've try *#*#4636#*#* code but nothing happen
what's my problem? i hope can find my problem solving here..
i'm sooooo sorry for my bad english :rolleyes::p:D
thank's before :)
Upvote 0
Unfortunately I can't really help you with this. My provider doesn't have 3G so I don't even know if it works.
All I can think of it that you can try experimenting by tweaking some settings at Settings -> Mobile Networks -> Network mode.
Or you can try as well baseband CA-201L 470. Though I'm not sure the Camera works with that baseband.
Upvote 0
i've already try anything with the setting but still same result
i'll try with that baseband, already download, i read modmist.zip up there, where i can download it?
sorry for my bad english :(
thank you Doctoror :)
Upvote 0
You're welcome.
The modemst fix is now integrated in the 470 installer (as well as for M050 and M070 baseband).
Previously I extracted modemst1 and modemst2 partitions from a device with Korean baseband into installer. This installer fixed bootloops for guys that installed Korean baseband above Verizon one. I don't know what the partitions contain but I discovered it experimentally. Now I recently found that just erasing modemst1 and modemst2 gives the same effect. The erasing fix is integrated into installers.
Upvote 0
You're welcome.
okay i'll try it, so i can flash 470 with m070 firmware?
:D
Upvote 0
BEST TECH IN 2023
Smartphones
