aboatright
Android Expert
ATTENTION PLEASE!!!! ATTENTION PLEASE!!!!!
This is Stock
I feel i should mention that though this is a large rom. It is very handy to have on your sd card for an emergency.
Well this is what it is. A completely stock LG Spirit ROM that is flash able with CWM. This ROM is rooted and stock odexed and fully bloated just fresh out of the box.
Superuser is included as well as the 2nd init apk.
Credit to their original creators for SU and 2nd init.apk
Credit to GameTheory for the update script I was too lazy to write.
Download here
http://db.tt/Bh6PQ5JY
WARNING!!! If you are coming from cm10 do not forget to change the network mode back to lte before flashing or your 4g won't work!!!
You've been warned!!!
Simple install.
Factory reset
Install zip
Reboot and profit.
Say thanks if you like it.... I do this for fun.
Degenerate Droid Development
M.G.D. LLC.
This is Stock
Download here
Simple install.
Factory reset
Install zip
Reboot and profit.
M.G.D. LLC.
