Leslie Ann
Android Expert
This is the stock Sprint rom in a flashable zip format (like other roms).
It comes in odex, what your phone came with and deodex, which is easier to theme.
These can be used to restore your phone back to stock, use them as the basis of your own rom (just like Aeneas) or use it for parts.
Please remember to thank those who help you accomplish your ideal rom.
Important Notes:
1. Unfortunately, at the moment, the deodex version is not booting. If you intend to build a rom from this, you might want to experiment with this, and then swap out the odex files later when I get it working. Some devs prefer odex for the speed, even if it makes it more difficult to modify.
2.I have no way to verify if 3g is working since my phone isn't activated. If you flash this, please let me know if 3g works. It should.
3. At the moment, your mac address will be altered. Once I get the deodexed version booting, I will correct that and release an Aeneas rom and possibly Sprint version of Harmonia as well. For now I just wanted to get this up for you guys and let you know I haven't forgotten about you.
Stock Sprint Odex
Md5: 3ad8ac030c246fed3d30002e077b517e
Changelog:
11Oct12 - initial release
Important Notes:
Stock Sprint Odex
Changelog:
