BH_MAN
Android Expert
I spent the night working on an update.zip for everyone, I know the likely of it being used is far and between, but wanted to give people Option's for flashing as well being able to flash on the go like I do
Before we start, I installed the Factory Rom here > True Stock 2.1 firmware for vibrant - xda-developers
This likely don't matter, I just flashed based on Reports it had better signal.
To boot Downloader Mode, Power off Phone!
Hold Volume up + Down & Hit the Power button ( Do not Hold the Power button, only Both Volume Key's )
Secondly, I had Flashed this Root method here > Root your Vibrant - xda-developers
To Root my Phone before I started
You can also boot into Recovery by Holding Volume Up + Power
From this Point, I installed Koush Rom Manager app & selected Vibrant when asked ( P.S. Huge fan of Koush's work ).
After I had downloaded the Recovery via Rom Manager, I booted into recovery and ran the update.zip which booted me into ClockworkMod Recovery mod.
Once inside ClockworkMod the Power button on my Phone no longer Select the Option you are wishing to use, I did however Noticed that the back key ( Next to the Search ) did however work for making selection via Menu.
For now, this update will not flash the zImage, I'll be adding that in the Next update, or trying to once I get more familiar with the Phone.
Rom ~ Stock_Vibrant > STock_Vibrant.zip
*Feature's*
- Stock
- Rooted
- Busybox
- Busybox symlinks Fully working
*Feature's*
- Stock
- Rooted
- Busybox
That has to be the fastest any Vibrant's gone from the box to rooted ever. I'm brand new to the rooting scene, having just flashed (old school computer term I know) the rom on my wife's old G1 to the newest Cyanogenmod 6 (Android 2.2). It's sad in a way that my brand new Vibrant is now running older software than an old G1. I look forward to someday rooting and flashing a custom rom to my Vibrant, but for now I'm still happy enough.
