Root [ROM][Supreme] Mobster Rom S - 03/30/14
Mobstergunz
Android Expert
Mobster Rom S
by Mobstergunz
Features:
Replaced Some Apps
Slimmed Down Rom
SD Cards Swapped
Adobe Flash Player
Enhanced Audio
Sony Bravia Engine 3
Custom KitKat Theme
Performance Tweaks
and More Not Mentioned.........
Installation Instructions:
1 Backup/Nandroid
2 Wipe Cache and Dalvik Cache
3 Wipe Data (Factory Reset)
4 Install Mobster Rom S
5 Reboot
6 Enjoy
Download:
Link - Mobster Rom S 022314.zip - 271 MB
Screenshots:
DISCLAIMER: I AM NOT RESPONSIBLE FOR ANY DAMAGE YOU FLASH AT YOUR OWN RISK
Changelog:
03/30/2014
  • Bug Fixes including Wifi
  • Fixed 3G icon
  • Updated to B.09
  • Misc stuff
02/23/2014
  • Bug Free
02/09/2014
  • Performance Enhanments
  • Bug Fixes
  • App Changes
  • 4G Icon Fixed
  • Misc Changes
02/01/2014
  • Rom Released
Thanks for the feed back :) I was thinking of adding more apps what do you think?
And there's still more I want to do with the Rom so when I have more time like I did I will definitely be working on it ;)
Edit: possible glitch - phone settings stuck on automatic brightness
Adding apps helps add flavor to the rom for sure... But usually less is more, at least to me.
When I'm building a rom, anything that can be downloaded from the play store I usually leave out (talk/hangouts, YouTube, google play music, etc). That doesn't include calendar and stuff like that obviously cause those are important to keep.
But adding an app that can adblock, overclock the phone, or add some hidden settings would help! I would say to have gravitybox installed, but that has to go through xposed so that's complicated.
If you add some apps to add flavor, just put them in data/app so that people who hate them can just uninstall them :) Putting new system apps in is cool too just make sure they'll be used.
These are just my preferences though and you don't have to listen to them lol.
I forgot to test the enhanced audio out. Whoops. I recovered from a backup to the stock rom and I'm seriously missing those white status bar icons already
The problem I am having is when I first try to connect to my WiFi it appears to be stuck at obtaining an IP address, if I reboot it will show its connected however it flashes between connected to obtaining an IP address very quickly and never actually connects. Its a very weird issue lol.
I am facing same issue. WIFI icon flickers.. and wifi just connect, reconnects forever. even restarted and tried airplane mode trick..
Not sure if this will help, but the warp2 had a similar wifi issue with stock roms. The solution was to uncheck "Avoid no internet connections" in wifi advanced settings.
There are some apparent bugs. It seems restarting the phone alot changes a lot of things
WiFi is not working. It is either stuck on Obtaining IP address or flickers between Connected and Obtaining IP address or says Connected but there is no internet. I tried with both 2.4ghz and 5ghz.
Airplane mode has problems too. Holding down the lock button and selecting airplane mode does nothing. And selecting airplane mode in the settings does nothing also. But if I restart it works normally. But if I restart again it not working anymore.
Bluetooth seems to be working. It turns on and off faster than it did in the stock rom.
There is definitely radio control issues with this rom.
About the automatic brightness glitch, sometimes it works sometimes it does not, depending on how many times you restart.
Its a great start though. I would also like the News and Weather app back. I use that alot.
I just booted into recovery and wiped data and wiped cache and dalvik cache and reboot it worked fine currently using rom now
I have to agree about the radio in general. Not really the ROM, but Bluetooth and WiFi doesn't play well together on this phone anyway.
I would have to say it is more than likely an issue with the rom. After flashing with the stock rom and Super R's Stock B06 unmodified and deodexed the wireless and 3g data work without any problems at all.
i have rooted my phone that is all, im working on installing CWM recovery now.
im trying to install this rom .
anything that could help would be great thanks.
Device: ZTE Supreme
Carrier : Virgin Mobile
Model Number: N9810
Android Version: 4.1.2 Jelly Bean
Thank You. :D
