Root Rom that has HDMI out working
I did some looking but really never found the answer I was looking for.
Can anyone point me in the direction of a rom that has hdmi out working so I can use it with cheapcast and my TV.
Also if there is nothing out there that has it working, can someone point me to a good instruction on how to go back to stock. I have not searched yet for the unrooting guide as I was hoping there was a rom that had hdmi out working.
Thanks in advance.
I have the MHL to HDMI adapter from Monoprice. While I was on stock, the output was only so-so, frequently losing sync and often very choppy.
I have not yet tried it with the CM10.2 nightlies, but I can take it for a test drive this weekend.
i believe the lg spectrum was the fisrt phone to have the same aspect ratio as lg widescreen tv's....so you can connect them for a 720p perfect output. that was the idea
i have never been able to get it to work with any aftermarket roms
I think 4.1 was the last version that has working mhl. Worked in both cm and aokp.
I remember I did use MHL to HDTV and worked good on CM 10.2 nightly a month ago. Indeed stock rom is choppy with HDTV.
Edit: Just checked now with ZV9 Stock ROM on Spectrum and seem run much better than ZV7 ROM. Noticeable frame freezing on HDTV on netflix in Spectrum phone, same as loss of sync repeatedly.
Does anyone know what cm10.2 nighly it was that worked with mhl?
