Whats the best settings ? i have a very fast and smooth ROM, i would like to know which is the best setting for it to stop forcing itself which it makes battery drain faster
What ROM do you have? Max 245, Min 122 when the screen is off, turn down your brightness as low as tolerable, turn off your 4G when not in use... etc....
If force close what version are u using to fix you need to go to the manage apps scroll down to rom tool box pro wipe the cache first .i repeat wipe the cache first then wipe the data . Now start what you want to do with the tool box
Well forcing itself as Doing a lot when is not needed, for example im at school and im not using it, later when i go to check the time battery is low, so i guess it forces itself to keep stuff running, and i am using a ROM called LD-LG ZVD v3.3
