AndroidDaytona
Build prop tweaks, kernel tweaks...etc. safe changes?
There should be a guide... 8)
it is a good investment, i use it all the time for backing up apps, buildprop stuff, whatever.
I have it just curious about heapsize,LCD density, and others
heapsize not sur eabout, o know it has something to do with your cache size and other stuff..just google it. LCD density changes the size of your screens..you can experiment if you want but just remeber the original valuesI have it just curious about heapsize,LCD density, and others
hope you feel betterOn that, you would do better by following the build prop tweaks thread on this site. You can just do a search for build prop tweaks for samsung admire. I'm sorry but I really don't feel well today or I would get the link for you. The values we list aren't even an option in the preset list he has. When you search them out here there is a long list of tweaks.
Anna
the themes from rom toolbox? idk, ive never tried to apply themes from it. i know boot anis work thoDo the themes work with our miui rom?
you should post in the evo4g sectionI'm a NOOB and I would appreciate any advice anyone might have to the following question: I have just successfully rooted my Evo 4g. I purchased and installed MYBackup Pro prior to unlocking and rooting my phone. I subsequently purchased and installed Titanium Backup after I rooted the phone. In addition to those apps I just installed ROM Toolbox Pro. Can anyone tell me if I need all three apps and what are the merits of one vs. the other? From what I can understand Titanium Backup is primarily used for managing apps and backing up files and data. ROM Toolbox Pro is primarily used for flashing custom ROMS, boot animations (what are those?) and things like setting the speed of your phone. It seems to me that all three apps perform similar functions. Am I on the right track?
