Root [ROM]Uber Z
JoelZ9614
<b>
If you like this ROM...
CLOCKWORKMOD 2.X.X.X ONLY FOR NOW!! HERE'S A TEMPORARY CWM 2.5.1.2[FLASH THIS AND THEN FLASH THE ROM]
Changelog
RLS1 [5/5/2011]-Rebuilt Completely With All Uber Customizations And New Z Rom Fixes and Ziggys 4/13 BFS Kernel. CWM 2 Only For Now :)
RLS2 [5/14/2011]- Sense 3.0 Style Dock,Transparent App Drawer And Notification Pull down, New Right Rosie Icon, Green Battery, New Notfication Toggles Theme.
RLS3 [5/14/2011]-New Lockscreen, New Right Button Icon, Updated LaunchKey, More Transparency In Rosie Dock, Updated To Flash 10.3, Fix For Notification Toggles (Widget.txt), Added Gadgets "Uber Green" HTC Skin.
Links RLS3:
UBER-Z-RLS3[FULL ROM][WIPE DATA AND CACHE!!]
UBER-Z-RLS3[Flashover For People On UBER-Z-RLS2 Already..NOT FULL ROM!!][WIPE CACHE AND DALVIK CACHE..NOT DATA!!!]
Kernels:
ZIGGY 3/12 BFS KERNEL
ZIGGY 4/10 BFS HAVS KERNEL
ZIGGY 4/15 BFS KERNEL
STOCK INCREDIBLE KERNEL
LOU'S KERNELS
Bugs
Touch Tones(Fix Settings>Sound>Audible Touch Tones>Long Tones)
You Tell Me :D
Thanks: Gmichaelow For All Of His Hard Work, Incubus26jc and MynFor Some Fixes And Icon, Jermaine Fixes, NilsP Fixes, IncDoes For Desire Z Port, Ziggy For His Kernel, Tommytomatoe For Having The Patience To Teach Me Some Things :D, TheImpaler747 For Helping Me, Gadget For His Right Rosie Icon And "Uber Green" HTC Skin</b>
i would say no cause skyraider 4.0 is not sense 2.0.....anything you can do i see over on xda there is a framewrk trick
Can anyone verify that the Navigation on this works properly? I've had problems with CM7 not correctly showing my location (which is a big problem when using Navigation), so I switched back to the original ROM. I would love to try this, but I need Navigation 100%. Thanks!
191mb isn't big? it's probably because you are used to AOSP Roms this is a Sense Roms and They are huge 180-210 mb usually and Aosp is 60-100mb at the most.
Oh alright, I wasn't familiar with the size of non AOSP ROMS. Thanks for the clarification and I look forward to trying the ROM. :D
