Root [ROM] UD 2.3!!! Hot of the presses!
messenger13
Android Expert
Here it is!
Ultimate Droid 2.3.0
- Updated All kernels
- Updated Browser app
- Updated Mms Features
- Updated Contacts app
- Scrollbars now invisible
- Updated Deskclock Features
- Added a more visible scroller
- Fixed compcache startup issue
- Fixed switching bootanimation issue
- Centered Date and Time on Lockscreen
- Added Phone and Messaging Tab Option for Lockscreen (rhurta)
- Added lockscreen gestures (mwebster - UDParts -> Input Settings)
- Play previous song when headset button is clicked three times (cyanogen)
- Changed deault wallpaper to "The Underdog" (androidandme.com - Ray Frenden)
- Pulled in some extra fixes from AOSP (framework, system core, build, bionic
from the changelog I don't see too many new features than from his most recent nightly...haven't played with it enough yet though, need sleep
2 issues i noticed right away...first, my apps didn't load directly from market like they normally do, had to use titatnium (not a huge deal). secondly, the open messaging on the lockscreen doesn't work, it does nothing. the phone works fine, but not the messaging. I had to change the sensitivity to 3 so that my other gestures wouldn't interfere.
anyone have these issues?
I could not get the apps to load, tried to sync my gmail and could not do that either. Stuck with nuttin'. Only rom that I ever had trouble loading on my phone. I don't know where to go from here except maybe install over 2.1.
Edit: Installed over 2.1, having trouble with 3G connection. It is sometimes will go off, reboot fixes. Maybe a install problem but I cannot install it properly. Still confused why it would not load up my gmail and the apps.
That sucks, hope you get it worked out.
2.2 is synonymous with Android 2.2 (Froyo), so it was skipped. At least that's what I heard through the grape vine. :)
Ever since installing 1.0.0 I've just been flashing over top without wiping any partitions. Haven't had a glitch yet.
So far, 2.3.0 is acting as expected (smooth) Unfortunately, I haven't had any time to check anything new. Maybe this afternoon...
Very nice ROM so far, my big test is A2DP BT voice dial and that WORKS :D
Now to put it through its paces but looking like a good, solid ROM. My only issue is the battery indicator... what is up with that? Oh well, all in the name of progress :rolleyes:
Installed without wiping and so far, so good!
Ok, everything seems to work, but I'm not seeing the messaging on lock screen options, lil help. maybe due to not wiping?
I really, really miss my red battery icon!!!!! Makes me want to scream about how it was red one day and the very next day it is now white!!!!
Oh well, this ROM still rocks!
Kratos
ahh, messenger, ya got it in there fast!
Kratos will not be happy :)
And somehow ... he'll get over it. :)
I will send you back to the depths of Hades! LOL :D;)
Just kidding, I was really just giving everyone a hard time about it. Like I said in the other thread, I don't care who starts the thread, I just want the .zip. To be honest, I got ready for bed, decided to check one last time and it was there. So, I clicked download from my phone and went to bed. I just finished flashing it this morning.
Kratos
I DL'd the 2.3 version and installed it. looks the same as 2.1
I went into UD settings and looked at the mod version, and it shows as 2.1.
installed without wiping and no problems
the messaging controls on the lock screen didn't work with the stock app
but work now that I set it to handcent it's working just fine
I cannot personally speak for the alternate links in this thread, but I can assure you that the OP is linked to UD 2.3.0. I would say just try again.
Kratos
