all right guys Im back from my break... I dont own the device anymore so I would need some testers if you want a update. The Rom is damn near perfect in my opinion. But I need to make some small tweaks
here you go
https://drive.google.com/file/d/0B6toRpM0-jNXeU9PUUlNNHhuR2M/edit?usp=sharing
Enjoy and give me feedback
You guys asked for a update. Any feedback?
hey i absolutly love the rom so far im only haveing a problem with the wifi it just keeps saying error? any ideas? ive tried the smart flash in 4ext ive tried reinstall with full wipes and i have tried a wimax app all with no success any help would be greatly appreciated. great rom tho keep up the good work
btw its a htc evo 3d 4g v if that makes a difference
It would be totes awesome if I could access the camera from a pin/pattern locked state! (Without entering pin/pattern)
This is by far the snappiest rom that still supports 3d I've found. CM 11 gives it a run for it's money otherwise (and that's kitkat!). I plan to figure out how to quickly switch between the two roms. I did have to downgrade to JBear 1.5 HBOOT to make it work.
Can someone help me figure out how to neuter this thing permanently to remove the carrier stuff? I'm using the phone as a tablet now and can't find anything that "sticks" in the off position after a power-down. Airplane mode doesn't work b/c I need bluetooth and *#*#4636#*#* turns the radio back on after every reboot. Since the phone already struggles to stay charged while navigating, running torque and listening to pandora (yep - car tablet) I really don't want the cell radio further draining the battery.
Thanks!
Hi, I want to try this rom but the download link is broken. Do you think you can repost it?You guys asked for a update. Any feedback?
