Root [ROM|UPGRADE|Android 2.3.5]ANARCHY RELOADED by Mastermind, First Ever Upgrade for Micromax A75
Thats the same thing i have provided in the package n also mentioned in my following thread.
http://androidforums.com/a75-all-th...niversal-method-increase-internal-memory.html
I modified original script to solve loosing IMEI n other nvram related data.
Now the original scripts on XDA also includes those changes(thanks to me n croniccorey:D) n u can see me resting in its credits list...i m now working with him to make this scripts completely universal...:D
I found your thread here with the same links, after I posted this morning..:o
Well done and good job..
I am a fan..
seey fr acting lik a noob.. bt wher will i exactly find d task switcher bro..n also set beats audio settings..
also wen r u actully releasing it fr a73..ppl r getting restless n porting themselves now..? :p
plz mastermind..do it dr dem fast.. or if u want i will upload it fr u n u cn make the thread.. n lik release it bro ?
Anarchy Reloaded released for Micromax A73 with some modification n including update 1.0 of A75.
http://androidforums.com/a73-all-th...mastermind-first-custom-rom-micromax-a73.html
Please test it n let me know there.
The sound has became too low dont know whats the problem please check on this and provide a solution for it.
One more problem is that after using the phone for around 3 to 4 hours the phone starts lagging and starts responding strangely. May be have to check in the V6 supercharger script and change the required values to make the ROM stable and smooth as it has to be always.
Mastermind please look into the following problems.
Ok just had similar issues like I had before when completing a call...
3g data connection enabled from SIM 1..WCDMA 2100 mHz on 3 UK.
Call made from SIM 2 and data connection was disabled as per normal.
Call connected and spoke to other party.
Other party ended the call and screen went blank.
Red LED still flashing as if call was still in progress.
Touchscreen and buttons not responding.
Had to remove battery and restart.
Never faced this issue with any other ROM. Is it a dialer issue or is it an issue when data connection is re-enabled automatically when voice call is completed?
Does ur device has LEDs????whats the device???A75 don't have LEDs...
There is small LED right next to the front camera which flashes when a call is active. It's quite faint but you can see it flashing when the call is active.It's rather exaggerated in this picture but the arrows and the ring point to where it is:
It's a Micromax A75, trust me..:)
Goto /data/nvram/APCFG/APRDCL
Delete Audio_Vol_custom
Reboot
If that don't help then try attached fix, flash via recovery.
sound is loud enough on my device so gave u file from my device.
He might be talking about the proximity sensor's red light flashing beside the speaker.
Please look into my problems.
found one more while charging if we try to use the phone it starts acting over smart and do what ever he feels like doing like open the status bar activating deactivating anything from it opening msging app writing msg if u press back key it will try to do something else when u click home key it will do something else.
Reboot
Ok thanks but what about the slowiness after 3 to 4 hours does the phone becames lazy or bored after 3 to 4 hours working or what???
Can't believe it..i never got that..no blinking led at there area in any rom..!!!:confused::confused::confused::confused::confused::confused:
just checked it again by making a call, switched of lights too,lol....:D no luck.
Buddy its a proximity sensor LED and its there in every A75 and it blinks when u have a active call and u can see it in light what happen to u mastermind dint had sleep or what as if this is the basic feature of our cell which help the phone to switch off the lights when we place the phone near our ears to save the battery and also to save the phone from misfucntioning.
I believe it is the proximity sensor which fires pulses of light to detect distance from objects and disable the touchscreen when a call is active..
For example if you keep the phone close to your ear like in a telephone conversation, the touchscreen should not work as any contact with the touchscreen will be interpreted as accidental..
Thats weired man....must be some voltage problem or problem with charger...n about slowiness, i have noticed that same with TaskSwitcher, i provided that on demand only, i don't use it n no such problem then...:p
Mate, i know that its proximity sensor n i know what it does but never noticed its blinking, thats y i got confused....:p
Without Task switcher were u be able to do multitasking on the phone and also i heard about some changes to be made in V6 check the below mentioned stuff. As i dont know how to do this so can u check this out and let me know.
lol! the performance gets slow after some time becoz the minfrees has been modded to have maximum multitasking
to solve this use option 6 on v6 supercharger script
Remove 97Superchargerv2 file from /system/etc/init.d (or move it to sdcard as backup)
Then use the device n see if there is some change...
If not satisfied then manually use superchagerv6 after removing that file from init.d (from original thread n original method n use option 6 as said by saivignesh)
Now see how u feel...tell me results n opinions...
EDIT:
Just went through original supercharger script n realized 97Superchargerv2 in rom already using the option 6 minfree values...
I suggest u rename 98tweakz to 95tweakz, allow supercharger to run last to avoid any conflict.
i have installed this rom, very good in terms of performance THANKS
I am facing some bugs:
1. gallery is not reading photos and videos
2.i installed mx player, it also doesn't read videos.
plz someone help.
Thanks
Backup whole your sdcard on pc 1st
Format sdcard (either from device or pc)
Then see if it works
Now u can restore ur files
anyway to less battery consumption in this rom, because at 10pm i cek 98% went wakeup at 5am has 62% in standby. it normal? in others rom not more at 5% . any suggestion? not use any aplication for batery booster because need more ram. please, i love this rom
May be batterystat.bin problem as even with two sim active i go to bed n it uses 10-15% battery.
Did u rebooted the device?sometimes I get battery percentage increased to some extent,trying to find out explanation for this.
What I advise-
- Charge the device fully to 100% till u get notification of fully charged
- Keep the power cord attached
- Open Root Explorer n delete /data/system/batterystats.bin file
- Power off the device
- It will now show offline charging(notice how much it shows), let it be for 3-5 min (100%)
- Now power on the device, this will calibrate battery n create a fresh batterystats.bin file
Still have the issue then install some battery monitor (Go Power Master) n see what is using the battery actually, system's battery use will not help so....
EDIT:
So no need to do anything correct may be as if the task switcher gives the best multitasking so it has all the apps open in it what we used so might be cos of that the phone becomes slow so need to see if it can close the unused apps and let the most recent 5 to 6 apps open.
Hey Mastermind cant we have different colour in the network bars like one to be blue or red and the other to be green or purple or else the colour what we select in the sim management should be used as network bar colour.
That will need whole new apk modification...i will have to undo many mods in framework too...may be i will do it for u but u will have to wait.
No hurry buddy if its a problem then i am happy with what i have but haan if u can do it with keeping all the other MODs as it is then only do it as if u have put much efforts in getting from Anarchy(Network Issuees) to Anarchy Reloaded(Smooth, Stable, Fast, Efficient and Fun to Use). So try if u can without effecting other MODs of urs.
I will try to get a framework that will show chosen sim background color for network icons only(signal bar only, not data connectivity). is this ok?or u want background color for data connectivity icon as well???i can do that too.:D
how can i make go launcher as default launcher and how to delete holo launcher ?
Holo Launcher is system app, named as Launcher2.apk...
Get Go Launcher apk
Put it in /system/app/ n set permissions to rw-r--r-- using Root Explorer
Reboot the device
Now, it will ask for which launcher to use, select Go Launcher
Now go to /system/app/ n delete Launcher2.apk
This will remove the Holo Launcher n make Go Launcher the default one.
