Trident
Android Expert
Please read this entire post before proceeding!
Features:
-ERE27 Android 2.1 VS740ZVB Base (credit to Google)
-Fully Zipaligned and Deodexed System
-Init.d boot sequence
-Custom Static Wallpapers (thanks RedFury, Vmanisme, and Jedii)
-Tons of tweaks to increase performance & battery life
-Google DNS for a faster and safer online experience
-System Audio from the Droid X
-Longer Duration Between Wifi Scans Tweak *Battery Saver*
-Version Information In Settings > About Phone
-Ads blocked by default in apps & browser *No need to use AdFree*
-Camera Sounds & Low Battery Sounds Silenced by default
-Optimized Native Process Manager *No need to use task killers*
-Percentage in Battery Icon (images by Xeudoxus)
-Velocity Boot Animation (thanks RedFury)
-Automatic Apps2SD, just create an ext partition on SD card and we do the rest (read me)
-Very fast and responsive!
Apps Included: *many moved to data partition for easy uninstall*
-Velocity About App (developed by RedFury)
-Native Sound Recorder App (thanks Pete)
-Testing App
-Flashlight App
-Spare Parts App (modded by Pete, customized by Trident)
-Velocity Tips Widget
-SuperUser (developed by ChainsDD)
-Terminal Emulator
-Droid X Live Wallpaper
-Droid X Video Player
-Droid 2 Live Wallpaper
-Barnacle Wifi Tether
-Astro File Manager
-ROM Manager
-Google News and Weather App
-Improved Google Car Home App
Tools and Utilities:
-Busybox
-Nano Text Editor
Scripts:
-ads show or block ads
-browser remove or restore browser app
-calc remove or restore Calculator app
-carhome remove or restore Car Home app
-cpuinfo displays CPU information
-email remove or restore Email app
-fixperm fixes script and Busybox permissions
-genie remove or restore News & Weather app
-lwp remove or restore Live Wallpaper apps
-mms remove or restore messaging app
-ota enable or disable OTA updates
-switchboot switch boot animation
-sys mount system as read only or write only
-usb enable or disable USB storage
-velocityboot enable or disable Velocity boot animation
http://androidforums.com/trident/177160-how-using-scripts.html
Removed:
-Amazon
-Amazon MP3
-Backup Assistant
-CityID
-Corporate Calendar
-Corporate Directory
-LG Bookmarks Widget
-LG Calendar Widget
-LG Clock Weather Widget
-LG Digital Alarm Widget
-LG Dual Clock Widget
-LG Home
-LG Home Selector
-LG Message Widget
-LG Socialite
-MySpace
-MyVerizon
-Skype
-Think Free Office
-Visual Voicemail
To install these apps back to the system/app partition, simply do the following:
1. Place the desired app on the root of your SD card
2. Launch Terminal Emulator
3. Type "su"
4. Type "sys -rw"
5. Type "cat /sdcard/example.apk > /system/app/example.apk"
6. Type "sys -ro"
3. Type "su"
4. Type "sys -rw"
6. Type "sys -ro"
Theme: (credit to RedFury)
-Complete Dark Theme
-Modded services.jar file (for white clock)
-White text in all ongoing system notifications
Gridlock Kernel Information:
-Deadline is the default I/O Scheduler
-Netfilter Support
-IP Tables Enabled
-RNDIS Support/USB Gadget Support
-Swap Support (If you intend on using, please see this notice)
-ext3 and ext4 Support
Release Notes:
-Wiping data, cache, and Dalvik cache is MANDATORY
-I recommended ROM Manager and ClockworkMod Recovery
-ROM Manager OTA updates are enabled
-Developed in part with Peter Alfonso, RedFury, Gridlock, savoxis, and Vmanisme
-Check ROM download statistics here
-File hosting provided by Noodle Software!
ROM Download Link:
goo.gl/VnXo
Do not make mirrors or download from anywhere other than NoodleSoftware.com!
OPTIONAL ROM Add-ons:
Do not install any ROM add-ons unless they have been adapted to work for Velocity by me and are located in this post. Velocity now requires special adjustment for nearly all add-ons. To request something to be adapted, please PM me.
-Android Stock Theme
Don't like the new Velocity theme? Flash this just like you would flash a kernel. Do not apply over anything other than Velocity stock theme!
Download
-Baseband Version VS740MVB.5210.1015: (new radio.img)
Flash this just like a kernel. You must reboot into recovery once more after installing to wipe your cache.
*Only flash once! I cannot be held liable for any damage caused to your device by flashing this!
Download
-GNM Overclock Kernel:
Information
Download Version Adapted for Velocity V0.3
-GNM Turbo 4:
Information
Download Version Adapted for Velocity V0.3 (with kernel)
Download Version Adapted for Velocity V0.3 (without kernel)
Remember where you saw all of these options first..
ENJOY!
Have any questions, comments, concerns, or suggestions? Post them here!
*Please do not "kang" anything from my work without my permission. Always remember to give credit where it is due. I work very hard on my projects.
