HELP!!! AND QUESTION...
SO WITH THIS KERNNEL. I DON'T HAVE TO INSTALL GNM TURBO4 W/O KERNNEL????
I ROOTED W/ UNI ANDROID, THEN TRIED TO INSTALL GNMTURBO4 BEFORE INSTALLING LG Ally Kernel 2.6.29.6_GNM_OC ... IN ROM PRE-INSTALL, I CHECK BACPUP EXISTING ROM AND WIPE DATA AND CACHE... MY PHONE HAS BEEN STUCK IN VELOCITY B00T LOOP SINCE. 1. WHAT DID I DO WRONG? 2. HOW CAN I FIX IT AND ADD YOUR KERNNEL???
THANKS FOR ANY HELP,
EZ
Something similar happened to me today. I went to put on GNM Turbo after using .3 since its release, I ended up with boot loops. I then restored back to .2 which worked fine but have tried flashing to .3 twice now and still getting stuck in boot loops. Thinking it may have something to do with OTA update which btw I ignored everytime it popped up.For some reason i can no longer install velocity. One day velocity crashed (everything would just force close, and nothing would load). So i flashed back to stock and when i attempt to reflash the rom with anything except a stock based ROM i get boot loops. HALP MEH!! lol
Well if you ever get rooted again, I have erased a file inside the rom called SystemUpdater.apk is roughly 74.1 kb then resigned the rom and reflash it, it hasent had it ask me to update again.anybody get an OTA update? i didnt pay attention and hit install now... now its stuck with a exclamation mark :/
ota -d
i know there was something about why he left ota updates on... i forget but its all fixed now. i removed the battery and the phone restarted fine, it says its up to date nowWell if you ever get rooted again, I have erased a file inside the rom called SystemUpdater.apk is roughly 74.1 kb then resigned the rom and reflash it, it hasent had it ask me to update again.
oooor....
Type
in terminal emulator and press enter.Code:ota -d
i ran into this issue with 0.2 actually lol when i flashed to 0.3 i got it back.... its a velocity related issue but odd to see it happen the other way aroundhas anyone had an issue with their vibration?
I had 0.3 up and running for a few days, then suddenly my vibration stopped working. I called verizon and they authorized a warranty return, but after I reflashed the stock ROM, vibration came back. I reflashed to velocity 0.2 and all seems to be well again.
Do you think this is velocity related or should I go ahead and convince them to warranty out my phone?
hey i had to reflash and got it to work.
To get that kernel to work right, I had to flash the TurboIV w/o kernel first. Cleared the caches, then flashed the new kernel. Cleared the caches again.
Hopefully you ran a nand backup before flashing, you can just recover back to the working state of your phone and try again.
Try reflashing the TurboIV w/out kernel rom, then clear the caches, and reboot back to recovery. Then flash the kernel and clear the caches again. When your phones boots to android it shouldn't get stuck in the loop.
Good luck. If you have any more trouble, highly recommend the IRC channel. the guys there are very helpful and knowledgeable and willing to help out with major issues.
IS THERE A GUIDE ON HOW TO USE the IRC channel. ican not figure out how to interact with the folks on IRC... thanks,
ez
It's best to have a class 6, but it will work with lower class cards as well.
