So it's been a little while since I've installed V0.3 without the turbo or OC kernel and there are still no problems! I can't believe how well it's all working! My sister has a Droid 2 and is jealous of how well my little Ally is running (well that and the keyboard HAHAHA)! Great job Trident! Super excited about the "Are you ready" V0.4 update, though I haven't done the back up yet, I want a class 6 SD card for V0.4. Which is why I'm writing today! I want to copy my entire sd card over to a Class 6 one but I don't know how to view the files and partitions on the sd card I have. Does anyone have a decent method for "ghosting" an SD card using windows (windows xp pro)?
Ghosting an SDcard does not work in xp. The partition you want to ghost is a ext3 partition. You may be able to use a linux live (ubuntu) cd but there is a more trusted method.
Guide to update SDcard from class 2-4 to class 6
1) Go to ROM manager and reboot to recovery or Power off phone then boot holding SEND+MENU+PWR and let go when you see LG Logo.
2) Backup your NAND and ext3 with clockworkmod NANDROID. You now have the ext3 partition backed up.
	3) Goto partitions menu -> mount USB storage then backup SD card to XP then end USB mount
3) Use power button to turn off or just pull battery
4) Put SD card in
5) boot holding SEND+MENU+PWR and let go when you see LG Logo.
6) Goto Advanced -> Partition SD card (if partition setting is not there then turn off phone reinsert old sd card and use Amon-RA recovery which can be found with ROM manager)
7) Goto partitions menu -> mount USB storage then restore SD card from XP then end USB mount
8) Wipe Data/Factory reset and do advanced -> Clear Davlik cache for shits and giggles
8) Restore your NAND and ext3 with clockworkmod NANDROID. You now have the ext3 partition restored.
If you have issues or bugs then I guess you should just restore your nand with old sd card and backup apps with titanium or velocitys new app backup tool and just reinstall the rom.
