Chris Broderick
Member
Did you put the icon on courtesy of an app (for example, Quick System Info Pro does that)? If so, you can remove those in that app's settings.
There was a mod for 4x5 Rosie, but I'll have to check where that is and if it's compatible with this version. I'll also see if I can find out if it's going into the upcoming release. No guarantees but I'll check.![]()
Hey EarlyMon,
I put the Icon on thru the Viper Hub just fooling with it but I can't find a way to remove it. Thanks for checking on the 4x5.
