Root Rom w/ Best Battery Life
1saint10
I'm going on a small road trip in a couple days and I need to be sure I can get atleast a full days worth of battery out of my phone. so now i'm wondering which is the best rom for battery life. suggestions?
Rather than the "best ROM" for battery life, it may be a good time to check into general tips and tricks for increasing battery life.
Turn off your wifi/gps/bluetooth/data if you aren't using it. Turn down screen brightness, ect.
You'd be surprised what you can squeeze out if you turn off what you don't need.
I'd also check into bringing a few extra batteries with, or a car charger :)
Thanks for all the tips. While i have you would you happen to know why google now no longer works on ics?
Google now is more integrated to work with Jellybean and the system. Previous versions of Google now aren't operational anymore so that's why it doesn't work with ICS anymore.
Google now sucks the juice, if you're looking for long lasting battery try butterz sense or harmonia with mirage kernel.
For jb, evervolv is one of the best battery friendly...when you get rid of Google now
I only asked about google now since the voice commands are very useful when im in the car but thanks for the info , i'm gonna give butterz sense a try and see what happens
Edit: flashed butterz sense with mirage & google now , everything works great. thanks for the recommendation.
