Root [ROM] Warp 4G Stock B12 KitKat 4.4.2 Deodexed and Unmodified
SuperR
Android Expert
Recognized Developer
DISCLAIMER: By using this rom, you agree that you are the only one responsible for anything good or bad that may occur. Use at your own risk.;)
For Boost Mobile ZTE Warp 4G N9510 only.
Completely Unmodified Stock B12 KitKat 4.4.2.
warplte_stock_B12.zip
Debloated and Deodexed Stock B12 KitKat 4.4.2 with Root.
warplte_stock_B12_deodexed_2.zip
/app/Books.apk
/app/ChromeWithBrowser.apk
/app/ConnectionsOptimizer.apk
/app/Hangouts.apk
/app/Magazines.apk
/app/MobileZone.apk
/app/Music2.apk
/app/PlusOne.apk
/app/SpanishPack.apk
/app/Swype.apk
/app/talkback.apk
/app/Videos.apk
/app/WorldTime.apk
/app/xtra_t_app.apk
/app/YouTube.apk
/lib/libchromeview.so
/lib/libSwypeCore.so
/media/bootanimation_sprint.zip
/media/bootanimation_virgin.zip
/priv-app/EmailZTE.apk
/priv-app/ExchangeZTE.apk
/priv-app/SprintID.apk
DOWNLOAD:
warplte_B12_NOT_FLASHABLE_deodexed_removed.zip
NOTE1:
If you have not updated to 4.4.2 (B12) via OTA, you should flash this partition updater AND the rom of choice. You only need to flash this once.
NOTE2: Your device must have CWM/PhilZ to flash ROMs.
NOTE3: These zips are unsigned so you will need to disable signature verification in CWM/PhilZ before flashing.
Flash in CWM/PhilZ as follows:
  1. Download ROM of choice
  2. Put the ROM.zip on your sdcard if not already
  3. Reboot to CWM/PhilZ Recovery
  4. MAKE A BACKUP!!!!!!!!!!
  5. Wipe data/Factoy reset
  6. Install partition updater from sdcard (see NOTE1 above)
  7. Install ROM from sdcard
  8. Reboot
  9. Enjoy!
Other Downloads/Links:
warplte_stock_B12_recovery_flashable.zip
warplte_stock_B12_kernel_flashable.zip
warplte_TB_fix.zip - Allows Titanium Backup and other apps to write to the external sdcard
UPDATE-SuperSU-v2.16.zip - Flash this after the unmodified ROM to get root
Root instructions for full stock 4.4.2 devices
Thanks to:
biasporpoise - Uploaded 4.4.2 B12 system files and partitions
Chainfire - For SuperSU
ZTE - For bringing KitKat to the Warp 4G
Is this legit KitKat? 0.0 cause I've been getting an update file for a while and it wouldn't install (ROM warp l 2.5 ROM)
Sorry for going noob, but I have a bad headache right now. Where do I get the latest CWM, and how do I install it?
My problems are that my security settings doesnt work and I can't uninstall an app, my phone reboots.
How did you install it?
Did you install the su zip?
Thanks
Thanks
My security settings work fine. I wiped for a new rom with PhilZ recovery, flashed the deodexed rom, flashed SuperSU, and flashed the partition updater
That's what I didn't flash, the partition updater, imma try it right now
Sorry that I offenended you man, didn't mean to, just complications on my part :p thanks
So I installed it the way you did and everything works great, no more reboot, security works and I can uninstall apps
Just a question of curiosity, does this ROM have a time deamon?
Thanks
Debloated version running good. Can I delete stock File Manager? If so, what is it called?...can't find it by that name in root explorer.
Thanks
Glad it's working now :)
Were you using the deodexed rom at first or were you using the unmodified rom? Trying to figure out if the partition updates are more important than I originally thought or if the unmodified rom has an issue the deodexed does not.
