davidmargolin
Android Expert
PER-APP-COLOR, Paranoidandroids newest invention. Define apps in your regular hybrid panel (same that allows you to scale apps individually and choose their interface). See your phone fade into the color definition of your current app, press home or go elsewhere and it fades back. Create as many combinations you like, you can even dabble with opacity. This feature is made possible by our hybrid engine, which is unique to this rom.
•Chose your statusbar style, regular PhoneUI, Nexus7-PhabletUI or a combined TabletUI systembar. Choose from a variety of toggles and toggle layouts, switches, holo-buttons, toggles or icon-text-toggle rows.
•Get a ton of features on top of Cyanogenmod’s catalogue. Dabble with opacity, see-through options, eventualy colors, etc.
•Our images and graphics are made by a dedicated artist, www.krebsmilk.de
•Hybrid mode is the heart and soul of paranoidandroid. Forget tablet mode or build.prop changes! Hybrid mode will not break your phone, your apps, your market, nothing will shrink or become unusable. Entire parts of AOSP have been rewritten to make this possible, you will not get anything like it anywhere, this is the only rom on Android capable of these things.
•Hybrid mode means you can control the size and the actual layout of any app individually. Keep in mind, apps bring their own layouts, they will display according to your device. That’s why apps like gmail, settings, youtube, camera, chrome, etc., transform completely when you run them on a tablet. This rom allows you to choose whatever layout you like best, we don’t fool around with DPI, we extract the actual layouts from your apk’s and you select them with a tap. Apply and you’re done. No reboot necessary. You can target anything: apps, system components, widgets, launchers, keyboards, statusbars, lockscreen, etc.
•Finetune your workspace or apply hybrid settings to all your apps if you don’t like to set them up individually. Individual settings will still override this so you can still get the look you want.
•For ease of use you can access hybrid properties in your recents view, this will allow you to quickly review changes. Basic things like recents, toggles, etc. have been made usable across all UI modes.
•Make sure you have a stable recovery installed, i recommend EXT4 Or TWRP
•Make sure you have an hboot that is not 1.57 or 1.58...
•Let it make a backup, just in case
•RECOVERY: WIPE ALL
•RECOVERY: Install Rom: Dev-Host - pa_shooter-2.99-20NOV2012-215100.zip - The Ultimate Free File Hosting / File Sharing Service
•RECOVERY: Install Gapps: Goo.im Downloads - Downloading gapps-jb-20121011-signed.zip
•Reboot and enjoy
•Our webpage: Paranoid Android - Home
•Complete guide to ParanoidPreferences: http://forum.xda-developers.com/showthread.php?t=1927208
•Get PA synced to your dropbox folder automatically, apply here: http://forum.xda-developers.com/showthread.php?t=1820276
•Themes and other goodies you can find here: http://forum.xda-developers.com/showthread.php?t=1646034
3D
MMS not working for VirginMobile like always
Fix: download this themed mms apk: Theme-D1-0rev6.apk
Or this unthemed mms apk: Mms.apk
Then install with root explorer by replacing with old mms.apk and set proper permissions
Expect to see updates frequently(based on when PA is updated and CM10 is updated)
Agrabren For the Base
Molesarecoming and the rest of the PA team
BigWillyg for the Kernel
Cyanogenmod Team
The Rom I ported From
DragunKorr for the build which is amazing and fully build from source. Him and his team put a ton of effort into this rom.
As well as ToryHeal420 and GaGilu and MikeDVH
Heres their thread and site and Github Paranoid Drag
