PlayfulGod
Extreme Android User
DISCLAIMER: This is a CUSTOM' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
CM 10.1 Hybrid Based ROM
Features
- Based on CM-10.1
- PA's hybrid engine for a full user experience
- Per App Layout
- Switch between three different UI modes
- Change the system DPI
- Add apps to different DPI groups
- AOKP Navbar
- Change the navigation bar height
- Clock Mods
- Notification Background
- Circle Battery Tweaks
- Wake up when device is plugged or no
- CRT Off Animations
- Notification Behaviours
- This is always a work in progress
Whats Not Working?
- Same things in CM-10.1
Downloads
Installation
- Copy the ROM to the SD
- Copy the GApps to the SD
- MAKE A BACKUP!!!
- Install the ROM and the GApps and
- If you are already in JellyBeer, wipe cache & dalvik
- If you come from any other ROM, wipe data or simply do a Factory Reset
- Reboot
People to Thank
- koush - for you wonderful recovery.
- BeerGang - for their their great work mashing JellyBeer in to a very nice ROM.
- CyanogenMod - for the best ROM on the planet.
- AOKP - for their wonder ROM.
- Paranoid - for their unique twist on things
- hroark13 - for his original work on the device repo in which this is based.
- Junkie2100 - for you relentless debugging, research, and testing.
- SuperR - for his devoted testing, debugging, and assistance.
- Anyone not mentioned - a great big thanks to you too.
