superboy4444
Android Expert
I present you with Party Time JBS. Just what is Party Time JB? Well, it's a ROM based on Martinez41613 Super Stock ICS ROM and it is a WIP (Work In Progress). It features things from Android 4.0, 4.1, & 4.2. I plan to work on this ROM to improve it. I hope everybody likes this ROM.
PartyTime JB v1.0 ..::https://docs.google.com/file/d/0B2xbJbHY20kuazlvQ2t3UWFZXzg/edit::..
Changelog:
v1.0
- Modded Build.prop
- Added Samsung App Store
- Added More Services App
- Made TouchWiz Stock Launcher
- Added Fully Functional S-Voice
- Added Fully Functional Google Now
- Added TouchWiz Gallery
- Added Stock My Files App
- Added JellyBean Transitions
- Modded Messaging App
- Fixed Camera to Gallery link bug
Bugs:
- Mobile Networks in Settings App Is Broken
- Wi-Fi Direct in Settings App Is Broken
PartyTime JB v1.2 ..::https://www.dropbox.com/s/at5v3q5vna0w375/PartyTimeJB1.2.zip::..
Mirror ..::Download PartyTimeJB1.2.zip from Sendspace.com - send big files the easy way::..
Thank you dobbs69 for mirror!
Mirror 2 ..::Party_TimeJB1.2.zip | ROM by Superboy4444 for Galaxy Reverb::..
My own mirror from androidfilehost. They just granted me a dev account so now i shouldn't be having any more traffic issues from now on!
Changelog:
v1.2
- Removed Stock ICS Gallery
- Added Favorite App Widget
- Changed Installation Scripting Slightly
- Added Swype Installer
- Fixed Wi-Fi direct bug in settings app
Bugs:
Party Time JBS v2.0 ..::http://www.androidfilehost.com/?fid=9390288116658473766::..
ChangeLog v2.0
- Added CRT TV Off animation
- Upgraded to AWESOME Beats v5
Bugs
- Mobile Networks in Settings App is Broken
Party Time JBS v2.1 ..::http://www.androidfilehost.com/?fid=9390288116658474043::..
ChangeLog v2.1
- Added GMail
- Added Google Maps/Navigation
- Added GMS_Core
- Enabled 4g Wimax Radio (No idea if this will work, I had the option in the phones framework-res so I did it, I am not in an area where it is available so i couldn't test it...at least not yet)
- Added VPN Client
Bugs
- Mobile Networks in Settings app is broken
- Opening Wallpaper is a little buggy just wait...
PartyTimeJBS 2.3 ..::http://www.androidfilehost.com/?fid=9390326628153819370::..
2.2 was epic fail
2.3 might be buggy still, i am working to improve it
changelong v2.3
- Check martinez thread for super stock ics
- kept jb4.1 fonts
- added swapps
- added lmt launcher
- give you the option for stock ics or touchwiz interface!
- 4g Wimax Capable!
- added My Account for those who requested!
- added Activation for those who requested!
- Removed all music players
- added custom music player from CM9
- custom wallpaper
- added tw wallpapers
- added mobile id to switch between launchers
- added cpu master...must install the same way as lmt launcher
- added animania's 1.8ghz default kernel!
- probably more that i'm not remembering!
bugs
- 4g settings in settings app is broken
- lmt launcher must be removed from system and installed normally from sd!!!
- boot animation missing...you'll see i think
- let me know!
Note for 2.3: The boot animation will not show, but that does not mean it will not boot, it will boot! Remember to do a full wipe to get the full effect! Remember, this is a ROM based off of martinez's superstock ics!
Party Time JBS 2.4: ..::http://www.androidfilehost.com/?fid=9390326628153819430::..
Changelog 2.4
- Fixed All Major Bugs with 2.3
Bugs
- Let me know!
Note for 2.4: It is integral that you do a data/factory reset and dalvik-cache wipe before flashing to get the full effect of this ROM!
Sorry for skipping 1.3 - 1.9, they all had major problems
Note 1: If upgrading from 1.0 or 1.2 to 2.0 then you do not need to wipe data/factory reset or even wipe dalvik cache. However, it is still recommended!
Note 2: You must flash ClockWorkMod Recovery 6.0.2.3 first! 6.0.2.7 will not work as of now! I find that test 8 is most reliable.
Disclaimer 1: If this Mod bricks your device there are a lot of things you can do to fix it. All you have to do is check on this forum. Also, if this Mod damages your device in any way, I take no responsibility, it is nobody's responsibility but your own. That being said, I have already tested and it finally runs perfectly on my phone.
Disclaimer 2: While installing this ROM using CWM Recovery, you will notice some profane language. If you are uncomfortable with this, the best i can do for now is say sorry.
Installation Instructions:
1. Download ROM and place wherever you would like (I keep my ROMs in a folder named ROMs located in my external sd card).
2. Boot into CWM Recovery
3. Wipe Data/Factory Reset
4. Advanced
3. Select Install zip from sd card
4. Select either install zip from sd card or install zip from external sd card
5. Select folder where you put PartyTime ROM.
6. Select PartyTime Rom (The Name will be PartyTime ICS because I forgot to rename it after updating).
7. Install
8. Reboot system
9. Wait at least 20 minutes before calling it a fail.
10. Voila
11. Welcome to the party!
Thank you everyone for your help including:
Martinez41613 for the Super Stock ICS ROM
TylerMetcalf1998 for working on this ROM with me over the phone
MikeyXDA for the Google Now Mod
AWESOME for Beats Audio Mod
WanamLite for the working S-Voice pulled from the SIII
And anyone who downloads this ROM and gives me input!
Thank You,
Enjoy!
Changelog:
v1.0
- Modded Build.prop
Bugs:
Changelog:
v1.2
Bugs:
ChangeLog v2.0
Bugs
ChangeLog v2.1
- Added GMail
- Added GMS_Core
- Added VPN Client
Bugs
2.2 was epic fail
changelong v2.3
- kept jb4.1 fonts
- added swapps
- 4g Wimax Capable!
- custom wallpaper
bugs
- let me know!
Changelog 2.4
Bugs
- Let me know!
4. Advanced
7. Install
8. Reboot system
10. Voila
Thank You,
Enjoy!
