X10iUser
Android Expert
Details:
This is really just an extension of my X10 Res Mods Theme but thanks to zdzihu's xRecovery we can now flash user ROMS to the phone which has made things a whole lot simpler. This is based on zdzihu's rooted S.E 2.1, 2.0.2.A.0.24 ROM with a tweaked Res Mods Theme.
Installing:
You need to install xRecovery, then extract the folder named "Eminence v1.2" to /sdcard/xrecovery/backup, then reboot into xRecovery and use the Restore option to install the ROM to your phone. You can find a more detailed guide by hellsrage619 HERE
Credits:
MrRusch for his work on the framework mod, H0CKEY for the home screen ICONS, rabetionline for pointing out the obvious, zdzihu for xRecovery and the rooted ROM, Fightspit for the SuperCircle Mod, Kersey for pointing out the JIT issue, mbrad26 for THIS, Jassiered for the Animations & Calum for his Thread.
Change Log:
Not changed a great deal really, modified for the new update, changed the button press, new animations, JIT enabled, removed the recovery menu. I've not made the background so dark so it stands out a bit more and changed the bootscreen, also cleaned up the dialler buttons.
Included
3.D Gallery, BusyBox, FileManager, Gauge Battery Widget [free], HTC ime [Themed], LauncherPro, Linpack, Signal Strength Widget, Superuser, Tajm, Titanium Backup [Free Version], xRecovery, Rooted
Removed *
Chinese Text input, Creatouch, Digital Clock Widget, EManual, Emanual Launcher, Facebook, Face Recognition, Home Launcher, Latin IME, Learning Client, Moxiermail, Music, Officesuite, PC Companion, Playnow/Client/Back/App Installer, Quadrapop, Ringtones, Recent Calls, Status Switch, Semc/Checkin/Setup Wizard/TouchPal Korean Qwerty, Search Widget, Textinput TNG, Timescape/Plugin Manager/Provider/Themes, Track I.D, User Support, uWlop, Wallpaper
Features:
JIT
Framework Animations
SuperCircle Battery Mod
X10 Res Mods Styling
Extras:
Bootscreen, Comfertaa Font, Wallpaper
Screen Shots:
Boot Screen: (quality is better on the phone)
Download Links:
Download Link 1
Download Link 2
Download Link 3
PLEASE READ
You are free to use 99.9% for whatever you wish, HOWEVER, I created the lockscreen, I've used it in my themes, now this, and it's a feature, a signature if you like, of my work, which I don't wish to see used in other themes/ROMS, ESPECIALLY which are for the X10, and I don't think that's an unfair request, PLUS, if you are going to create something for the community, try and put your own stamp on it.
If you get a md5 "mismatch" error, smartgardens has posted a solution HERE. Or some have said renaming the folder, for example, "Eminence v1.2" to Eminence_v1.2" works also.
If you've not already used zdzihu's ROM and flashtool files to update to 2.0.2.A.0.24 then you need to update the Baseband as well. Doesn't matter if you don't, but as we all like to be upto date you might as well...
...so just run the flashtool from HEREYou need xRecovery to flash rooted system (and system only) image.
Then you need X10 flasher to flash all remaining parts (SIN files = kernel, baseband etc)
Cheers,
z
Market Issues Have Nothing To Do With Themes
* You can find most of the apps that have been removed HERE, and if it's not listed in the first post chances are you will find it somewhere in the thread.
Some extras for your X10:
Fonts
Bootscreens
60 SMS Tones
178 Game HD wallpapers
Hubble Telescope wallpapers
FHM Top 10 2010 wallpapers
2.1 System Apps/Framework Files
I'm trying to read through the 60+ page thread on XDA to figure out what's wrong.. but if anyone else knows how to get by this I'd appreciate the time saver
