Root [RomInfo] Juniper Elf 2 v1.1 by DaNish AsHraf (Dated 11/06/2013)
bubbasd
Note: This is DaNish-AsHraf's Juniper Elf 2 V1.1 (Dated 11/06/2013)
download links in source at bottom of the topic dated 2013-06-11
I have created my own custom rom based on 0926 stock rom for Ainol Novo7 Elf 2.
Many thanks to fuser-invent for directing me that how to make custom rom.
Juniper Elf 2 (v1.1 OUT NOW!)
Change log:
* Deodoxed Apps and Framework
* ZipAlign
Planned Features:
* Extended Power Menu
* Internal <-> External SD card swap zips
Download Link:
link
Juniper Elf 2 v1.0
Specification:
* Rooted
* Removed Chinese Apps and Bloatware
* Lightweight
* Compatible with CWM & TWRP recovery
* Custom Boot Animation
* Pre-Installed Light Google Apps Package
* No need to fingerprint to somedevices because all gameloft games are compatible with original fingerprint.
Download Links:
* You need to first flash the official Stock ROM package using the official stock recovery and u-boot.bin provided inside.
link
* I recommend a factory reset to make sure you get a clean install on your first flash. The rest of the Juniper Elf2 ROM files are built to flash in TWRP or CWM, which you can of course get from this link
link
* You can store recovery in nand via flash this zip.
link
* Download rom from this link.
link
Source:ciao:
Cheers :party:
