Root [ROMlCOLOURSl]PORTED FOR A75
shahabazas
~*~ Android Addict ~*~
New Rom COLOURS by Mmrehman of XDA has been released and to make it work on our A75 we just need to flash the Latest Stock Baseband zip,BOOt and Logo zip and the camera zip as if the camera is foreclosing what is in the ROM so once flashing the zip of ROM just flash the zip files provided below and you will have everything working.
SOME FEATURES OF ROM COLORS
* Android 2.3.5 Pre Roooted
* Bravia Engine & Beats Audio
* FM Radio without headphones
* Inbuilt data2Ext support
Credits:
Mmrehman for porting it to Spice and to MEfor porting and testing it on A75 and providing the fixes
Disclaimer/Warning:
I AM NOT RESPONSIBLE FOR ANY HARM DONE TO YOUR PHONE USING THIS . DONT BLAME ME IF YOUR PHONE TURNS INTO A PAPERWEIGHT/BRICKED USING THIS. DO IT ON YOUR OWN RISK.
How to flash well its the same way you flashed the other ROMs still wanna know ok
Installation:
1. Download the zips from Download link
2. Dump it to SD card
3. Reboot to recovery
4. Factory reset
5. Wipe cache
6. Go to Advanced
7. Wipe Dalvik Cache
8. Wipe Battery stats
9. Go back
10.Select install zip from SD card.
11.Select the ROM zip
12.Select Yes
13.Follow instruction of Aroma installer
14.After the flashing complete go back
14.Flash all the other zips provided for all the fixes one by one
15. Reboot
16.........ENJOY.......
First boot takes about 3 minutes.After first reboot, Open file explorer and go to SDcard ,Here you find Scripts folder and 01data2ext file.
JUST MOVE THIS FILE(01data2ext) TO Scripts folder AND REBOOT ONCE AGAIN.Second boot also takes about 3 minutes.
NOW OPEN SYSTEM INFORMATION & SEE THE INTERNAL MEMORY.
NOTE:SIM background colour wont work as it is modified to display some icons on signal strength.As general rule BATTERY SHOULD BE
CALIBRATED EVERY TIME WHENEVER YOU FLASH NEW ROM.So calibrate your battery properly.
Here are the download links:
Boot and Logo
A75Boot&Logo.zip
A75LatestStockBaseband.zip
Camera Fix
2.3.5CameraFix
ROM Download
Dev-Host - COLORS.zip - The Ultimate Free File Hosting / File Sharing Service
Important
Once reboot please download this build prop extract it and paste/replace with the build prop in /system folder and give permission as r-w-rr
A75Colours Build prop.rar
Original Thread for the ROM
http://forum.xda-developers.com/showthread.php?t=1880187
For any other problems if you face in future as if all the things are working with all the fixes what i have provided so if you get into any other problem then you can either post it over here or head over to the main ROM thread.
and hey dont forget to thanks Mmrehman on the main thread for porting it to spice.
ENJOY THE COLORFUL ROM
Screenshots:
Nice one, features seem awesome... but screenshots please??
Oh my god it feels so good to see your comment bro... after such a long time really feeling nice and thing that if you were about to comment then y wouldnt i have posted something before. Thanks.... and screenshots well will do it in 5mins.
is this modified lewa rom??
It is a ported rom.All the frameworks and apks are modified by weilai, Mmrehman have just ported it for Spice. removed some bugs and added some features to it. And finally i ported it for Micromax A75 with all the fixes.
bro u have u changed anything in rom?? coz u have provided link for seperate baseband and sagarwep's camera fix
The Baseband is of Micromax the latest one and the camera fix is not of sagarwep its mix match what i have got working when i was using Anarchy ROM and its working fine with this ROM.
No Doubt it's an Awesome ROM, And the Green Color is great. But you know what, I found out a big flaw with that Beats Audio Engine while I had my cell..
Micromax A75, Micromax A100, Micromax A110 and as well as Micromax A70 and A73 all support a MONO Type Headphone connector. That is, the 3.5mm pin has only 2 circles on it. Whileist, if you read the general requirements for Beats Mod you'll get that it require a STEREO type connector support with 3 Rings...
So even if Beats Audio is running and one is using a Beats Supported headphone "SOMEHOW", it's just doing the part of Equalizer. And not what Beats Audio must do.
So guess removing the beats part will give you around 1/2hr to 45 mins battery time increase...
Try it if you want. :) :) :)
Happy to be back here, and was following this forum since i left 4 months ago... :)
My both headsets MMX connector are having 3rings on them and as soon as i plug in d headphone the beats audio settings opens up and i can use it and i found a drastic change in d sound n beats and bro i can confirmed that A75 and A73 both are stereo as if i had experienced it while listening the songs which have stereo effect.
All the fixes are already uploaded to mediafire and the ROM is from d direct download link so you should not face any problem in downloading it.
bro...i am not able to download colour.zip from dev-host...
can u please upload in other host
D 90* rotated camera is there when u make video call but for taking photos from front or back camera its totally perfect.
he's saying that if u have saved some number without +91 then at the time of calls it will not show the contacts name
so u got save every number starting with +91
bro. i m facing this problme
my camera no working ..it shows th application camera (processcom.mediatek.camera) has stopped unexpectedly.please try again.
i have installed all your zip files
It should work bro as if i am using d same files and had provided it so it should work ok do one thing do a factory reset and reboot may be after that the permissions will be set correctly. So try it.
its so aewsome to see u guys back ! hv been missing u all !
@ AD @ shahbhaz !~
n awesome rom !
bt i had a seperate quer will pm u guys :)
bro. i have do the same....but still having same problem...
please help me to fix it
