Help ROM's, deodex and themes ?!?!?
chkmate
Ok...
Hope I'm in the right spot for this thread. Need support.
I have about 300 hours of reading in and I am still sitting with a Droid X, 2.2 OTA and no root. I know how to root with rootmyx2 1-click method, not an issue. Was rooted before 2.2 and didn't want any leaked versions.
I have every tool that I would ever need. Root Explorer, Titanium BU, ROM Manager and Droid X Recovery Bootstrap.
But I can't get a straight answer for what ROM's I can install with the 2.2 OTA and which ones deodex for me. I know the 928DroidBlackGlassX-DroidX-OTA2315-DeOdexEERR-THEME will deodex for you but from what I read you have to have a ROM first. So confused.
I read FlyX has been put on the 2.2 w/out deodex and others say you need it first.
I'm just looking for the easiest step-by-step instructions to get set up for themes on a DX 2.2 Official 2.2 OTA.
Like I said I read and read and want to make sure things are as clear as can be.
Thanks to any who read this far, Hats off:)
Check this out, I wanted to do this last week and asked for help and got some great information. It worked great with no problems.
Check this out, I wanted to do this...-things-root/194598-want-make-sure-right.html
You already have a ROM with the 2.2 OTA on your phone. If you want to try and new ROM, which I have after I did my first theme you would want to put that on first and then the theme because adding a ROM with overwrite your theme.
Hope this helps.
Correct, hook your X up to the computer copy the .zip file over your SD card (on the root of it) and then disconnect your X from the computer. Then you should be good to go.
