xcelprinting.com
With all the available roms, id like to know what are the pro's & cons of each, such as features, apps, and flaws, and "why" do you feel one rom is better over the other. Please be detailed, not just "this rom is the best".
Looking forward to future updates on this one!Pros and Cons.... hmm... Well here goes my ... erm... 2cents? It might not be Pros and Cons really, but atleast you get the jist, sorta... lol
Im sure I missed one or 2, or more... lol but those are the main ones, I believe that are out so far.
DamageControl::
- My opinion, could be one of the best ROMs out, but heading in the ways of AOSP-like, theres lots of bug fixes (as well as other ROMs below, which are heading in the same direction, same bugs, etc...) EIther way, great ROM, fast, great battery life. Has ability to enable JIT. Also comes in 2 versions, odexed and deodexed versions. I personally had a few problems backing up my apps using Titanium Backup, but im sure it will get fixed in later versions.
BuglessBeast::
- The ROM im personally using at me moment. And to be honest, i LOVE it. SUPER fast loading time (after restarts and shut offs etc...) LOVE the new boot screen, and the CPU-hogless-custom-Nexus-like-Live Wall paper is awesome! I use ADW Launcher on top of it, but I love it. The lockscreen is great. Battery life is VERY usable. Snappy, and cant wait for the updates. (Oh and, loving the AOSP elements that were implemented. ^_^ )
Aloysius::
- Again, not 100% sure about this one, but I believe this one, like Bugless Beast, can run on top of other ROMs, but this one gives your ROM a make over, changing ICONS and Status Bar, etc... very nice tho, I must say.
I personally use BuglessBeast and so far no problems and even helped me with the battery issue.
TS
I still haven't figured out what is JIT or hat its for, can you give explain a bit? Basically, in a nut shell, its a specific file compiler... makes things run faster. ^_^ kinda like... hmm. cache.
Also what is odexed and deodexed, and how do I know which one I should use? If I remember from another post... odexed is apps with attached file settings, and deodexed well... without. (Correct me if im wrong ^_^)
Why did you personally choose this one over Damage or Fresh?
To be honest, I thought I was going to stick with Fresh, due to the great amount of stability. But once I got Bugless 0.4 running pretty well. (with only one FC randomly happening, but not affecting me at all) I switched until further ROM updates. Other than that, theres really no specific reason I chose it, but I do have NAND backups of Fresh and Damage. (incase I want to switch / upgrade that specific ROM)
1) If I use rom manager, is this "self installing" or just adding the zip to my SD card Root for me to then follow steps 30-34? What ROM Manager does, if you download a ROM from the RM, it was save to a folder on your sdcard called "clockworkmod" then follow into download>>whatever file dev etc... (you'll find it xD ) But what it automatically does, is assume you want to flash it RIGHT after its done downloading. You dont have to, but it gives you the choice to nand backup before you flash it or not. *Not sure if that answered your question, but let me know if I didnt.*
2) say right now I was running fresh, but decide I want to try bugless, are you suppose to do a wipe, and a Dalvic wipe before installing another rom? And what type of backup am I doing? Usually the Dev will say something like "OMG REQUIRES WIPE BEFORE FLASH WARNING WARNING" LOL ok so I exaggerated a little bit... xD but no really, the Dev usually says something like "Will require wipe and cache wipe etc.." ALWAYS boot into recovery mode, and make a Nandroid Backup. Its the best way and safest to know you can always revert back to what you had last. (also do it before wiping.)
Just wonderinng since you mention how you may still keep the benefit of a previous rom even when installing over it.
Usually its probably not a good idea to install OVER another ROM, but I did it just for the heck of it really. Doing that usually causes lots of FCs and such. So usually only if your told its possible or not, dont do it, unless you want to see what happens.But I wouldnt suggest it.
Thanks for al your help.
