Root Roms
tns0608
I'm new to all this and I need some help. Which ROM is the best for a2...I see two on here, but which would you all recommend and what is the difference between them?...thanks in advance =)
I've been trying to flash this one-----> A2tude_1.75_signed.zip but after I do, I get the Huawei white screen. Maybe you'll have better luck. I've only seen two as well, A2tude and asCend2. Good luck, nobody seems to wanna help.
Try posting in the all things root section.:D
this is good advice here ;) If the phone has to be rooted then anything and everything related will be in that section. That will include ROMs, kernels, mods, how to, etc. It is also the main area I check as most everything I do requires root. ;)
