Root Roms
im using cyanogenmod 10.1 on my p5113
ive flashed 5 or 6 different ones for the tab2 and by far this is my favorite.
smooth interface, really stripped down of all the bloat and very responsive.
CM 10.1 nightlies are great on this device and theres even a kernel with 1.48 ghz capability making this tablet run smooth as butter.. my battery even lasts 2-3 days on average.
That's just awesome!
Where get this?
Google for xda forums and look for this tab under android development
This is an edit of all the best ROMs for this Tab..
Cyanogen 10.1
http://forum.xda-developers.com/showthread.php?t=2018386
Zap Blaster
http://forum.xda-developers.com/showthread.php?t=2133589
PAC Rom
http://forum.xda-developers.com/showthread.php?t=2202885
Carbon
http://forum.xda-developers.com/showthread.php?t=2210663
and for those who would like Stock and AOSP running as dual boots on your ROM which is crazy awesome!!
http://forum.xda-developers.com/showthread.php?t=2302663
I am currently DUAL booting Cyanogen 10.1 and Zap Blaster 2.2 ROMs.
Reason I am doing this is both ROMs run off of KK's NEXT Kernal (Overclockable) and well.. Cyanogen is the best ROM for any device in my opinion but sometimes doesn't have all the support for extra devices for the device like USB OTG (On the Go) (Which does work on CM) and the HDMI adapter(which doesn't work on CM) but all those work on Zap Blaster so I just reboot into this ROM to watch movies with my Tab 2 on my HDTV.
Anyways hope this helps! :)
