Accessories rooCASE Multi-View
Snazzy
Amazon.com: rooCASE Multi-View (Black) Leather Case Cover with 22 Angle Adjustable Stand for Barnes and Noble NOOKcolor Nook Color eBook Reader: Electronics
This leather case fits the Nook Color very well and the built in stand makes positioning this very well in the kitchen so I can follow a recipe. Construction is solid and when packed up for travel I feel the Nook could take a drop from my hands and be well protected by this case. The edges sit back from the screen enough so that all edges are completely touchable, very important to me.
My only con is small and that is when watching a video in landscape mode the two halves of the case kinda flop around which means I have to hold the device with two hands. I think I will work on affixing a clasp or some Velcro to keep it snug when rotated in landscape.
Here's another rooCase: Amazon.com: rooCASE Easy-View (Black) Leather Case Cover with Landscape Adjustable Stand for Barnes and Noble NOOKcolor Nook Color eBook Reader: Electronics
I just ordered this one: Amazon.com: CrazyOnDigital Folio Brown Leather Case with Screen Protector For Barnes & Noble Nook 2 Color NOOKColor: CrazyOnDigital
Not fond of the brown leather case for several reasons, but primarily b/c it has no snap or latch to keep it closed, but the enclosed screen protector is good for glare so not a complete loss. It probably is worth what I paid for it tho. I did have buyers remorse before it arrived, thinking I should have opted for the landscape rooCase I posted above. If you can find this protector, I recommend it:
I did not see it by itself on Amazon listed by CrazyOnDigital tho.
I have been using the roocase and so far I really like it. The stand works great. Cons: The latch has to be tucked under when using the stand and there is no extra storage which might be nice.
