Berry2Droid
First off, im running HC2.1,
1.Dont you have to root to be able to upgrade to a different software type? I rooted before in stalling greek35 2.1, then upgraded to HC2.1, do i have to reroot?
2. Rooting is just, using the update.zip file you download, then using droidroothelp.apk program, mount3, update those 3 things, flash 15.0, rename, reboot ect...so basically as long as you have SU app on your phone your rooted no?
Now boot animation question
I downloaded a boot animation, connected my phone with usb debugging, used the cd command and abd push bootanimation.zip /data/local, rebooted and the boot animation didnt change..after i used the push command, it said x.xkb transfered in 1.23seconds or whatever...any suggestions?
thanks
