Alright, this may be a bit nooby but.... I have 2 gb micro installed on my phone. Recently, I wanted to upgrade it to a 8gb micro. My query is if I transfer everything from my 2 gb onto the 8 gb, would it break the root or no?
simple answer is no. it will not break your root. when i switched from my 4g to my 8g it broke a few of my apps but that was easily fixed by a reinstall of the app. you would also need to reset your ringtones after the switch.
