Hello,
I just rooted my Casio C771 M150 using the auto root script on this forum. It works great. So, I decided to try PDAnet. It installs, seems to be working. I am able to start the wifi server, set up name pw. My tablet connects to it. However I still cant surf. I keep getting the Verizon built in hotspot prompt.
So, even though is rooted maybe still getting blocked by VZ?
Do I need to use anything else, am I missing the obvious? This is my first try.
I see that PDAnet may not be compatible with the C771, any other way to tether? Bluetooth does not appear to work either, not sure if USB is the answer.
TIA
Regards,
Rtr.
TIA
Regards,
Rtr.
) just send me another PM
