Root Root Battery life vs 2.2 OTA?
Rodent
Member
For those of you who rooted how much extra battery life do you get now? I go about 12 hours right now and have 20-30% left with stock if that is any indication of my usage.
Thanks!
Rooting will not in and of itself effect your battery life .... think of it as getting access to the administrative account on a computer versus a standard user account.... there would be no change in the performance of the machine by doing so.
What you can do however, is uninstall some of the bloatware, install custom kernels or ROMs with tweaks for battery life, and apps like SetCPU. All I have done is install a custom ROM and my battery life seems to be the same if not slightly worse than standard 2.2 OTA.
Thanks thats what I kinda figured. Yea I want to remove all their crap applications that came with the phone.
Great idea! IMO the bloatware is pointless, I used Titanium Backup to remove the bloatware and didn't have a single problem.
The best I had when my phone was bland and I as using root with stock 1300 battery was 34 hours up time with I think close to 10 hours awake time at 1% battery life. It was light to moderate usage.
Now, I have a lot more stuff on my phone, no bloatware, and use it with moderate to heavy useage but still get about 15 hours of uptime and I think I had 4-5 hours of awake time with 9% life.
