It worked gr8 ... Thanks dude... keep going ...
the point wer i struggled bit was
2. Run in maintenance mode (power + middle button)
I was trying when phone was on...Then i switched off and then pressed power + middle button to go to maintenance mode.. then it worked...gr8...
I have 2 questions1. Download attached file and copy it to your sdcard
3. Update from sdcard, select the file upd_1.zip.
4. After the update completed - reboot in normal mode.
Thats all - now you have rooted ace with android 2.3.3, and superuser in your apps.
Hi guys,
I've been using my s5830 for four days now after flashing it from Froyo to Gingerbread 2.3.4
Do anyone experience about 1.5 sec response before the unlock screen appears?
And also, I experience setting the phone in Vibrate / Silent, but when I receive an SMS message, the message alert tone goes off and the phone is not on silent mode anymore.
Is there any fix for this? Or do I just have my setting wrong?
Note:
I rooted my phone and set an mp3 file as message alert tone
I just got my new Galaxy Ace which came directly with Andoird 2.3.3.
I can say it is one of the most disappointing products that I purchased.
The phone looks great and I was glad that it had already 2.3.3 on it as specs said 2.2. It moves nice and also good interface both hard and software.
BUT I COULD NOT USE THE PHONE FOR MORE THEN 2-3 MINUTES CONTINOUSLY.
It resets and blocks and hangs when using the most basic and simple operations. When put to charge I can it shuts down after a while and I can started only after removing and puting back the battery.
I'm rather now in opinion that quality assurance of Samsung is null. I had last year again a new phone from Samsung and it came with the camera not working from factory.
Can anyone confirm similar problems with Galaxy Ace?
So this means that Gingerbread 2.3 can be rooted already ? I want to root my HTC Evo 4G..... Thanks in advance
i have rooted successfully. I can see superuser app. but there is no change in version. its showing 2.2.1 not 2.3.x. please frnds let me know what went wrong..
